PHD / augers in rocky soil
gpurp
M5140
Nov 9, 2016
Hi all. I just bought a nice M5140 with low hours and would like to get an auger. I've got my eye on a Landpride PD25 as it appears to be a good match for the tractor in size and weight. I'm wondering how well it works in rocky soil. I have a few acres in north Texas and the soil has a lot of clay and sedimentary rock. The property was previously unfenced so I need to set some corner posts. There's no way I could dig them by hand. Just wondering what others experiences were in soil like this.
Sent from my SM-G925V using Tapatalk
bearskinner
Sep 1, 2014
926
241
N. Idaho
My little BX PHD and auger can only put a 6x6" post 30" down, but I am totally amazed with how it digs in extremely rocky soil. That auger pulls softballs out and works great.
SkylineAcres16
Kubota MX5800 HST, International B-275 Diesel
Sep 3, 2016
40
It will be a lot better than digging by hand, however, don't expect a miracle. Have a digging bar with you......
John Corey
Kubota Sunshine L1-22DT
Oct 30, 2015
46
Gold Coast Australia
Like Skyline says, don't expect miracles. Clay is the 'natural enemy' of the auger. I have 5 acres on the Gold Coast of Australia and the soil is mostly clay. I always have a good digging bar with me as sometimes the auger will go straight down for me to 600ml (which is what I want) and other times it wont make a dent. So I have to break away the clay/rock with the digging bar first.
I also upgraded my auger blades/teeth to tungsten which has made a big difference to the standard teeth that came with the auger.
gpurp
M5140
Nov 9, 2016
Thanks for the replies and advice. If it hits a big rock then I don't expect to bore through it. Landpride does make a hydraulic attachment that applies up to 500lbs down pressure. I'd be curious to see how that worked.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
if I was buying a new one it would have the hyd down pressure. That extra 500 lbs of force Most of the time means digging or not in hard ground. I used a Bushhog brand with down pressure, it worked great.
