Wildfire
Even though my Kubota Grand L has a warning lamp built into the instrument cluster I still have driven off with the park brake on. I guess the park brake warning light is kind of down and out of the way so I don't notice it much. Well I decided to add another LED light to the beast and it cost me a whopping $6.97 (Wal-Mart) and 20 minutes to do it. I first placed the light in an area where I knew I would see it. I ran two wires to ground and the other 12 volt fused I ran to one leg of the micro switch that was already on the park brake. The original light still works in the cluster and this is just an extra warning light.
For the folks that don't have a warning light at all just get yourself a switch like that's on the Kubota Grand L's and it will work with the only difference is that you'll have to add a 12 volt power source. For the folks that don't have a cab you could use a soft sounding buzzer instead of a light is you wished to. just something to consider. This will prevent me from driving off with the brake on now (I hope)
Below is the park brake micro switch.
As you can see it's very thin.
This picture shows where I mounted it.
Short YouTube video:
http://www.youtube.com/watch?v=PDg6_8Wnw6A
