P-208B code…..Please Help!!
GlidePilot893
M5-111, M4-071, RCR2596 & RC3715
May 18, 2024
I was preparing to start cutting and baking hay tomorrow to try to get some done before a chance of rain on Thursday. My 2016 M5-111 is beeping and has Engine P-208B Code and is in count down mode to 80% Power Reduction….the code is a generic DEF code regarding Reductant Pump Control/Range. Is this common and what could the issue be?
Any and ALL help is greatly appreciated….
7,735
You know it really helps if you use the Kubota WSM and Kubota codes to figure out what's wrong.
It's a heck of a lot more accurate than an internet answer to a code, which by the way is wrong because kubota does not use standard OBII codes. :unsure:
Look on page 10-93 for the exact answer to your code, and what to look at to fix it. ;)
whitetiger
Nov 20, 2011
2,996
1,450
Kansas City, KS
Here is the DTC info from the M5-111 WSM. Looks like it is going to have to be diagnosed using Diagmaster though.
GlidePilot893
May 18, 2024
Thank You for posting as I was not aware of the status of Kubota not using OBDII Codes.Your comment was helpful!!
