Operator Manual for BX2750D Snowblower for Maintenance info
kupitz
BX2660 with LA243 FEL and Front mount BX2750 snowblower/2763A heated Curtis cab.
Mar 28, 2016
130
New Providence, PA
Anyone have a copy they can share? I did a search and saw a response to a previous inquiry to PM a user here but doesn't appear he is a member anymore. Just want to be sure I am hitting all the correct lube points is what I'm after. I only see the 2 zerks on the main auger and of course on the driveshaft u joints. Other than those and spraying the drive chain with lube, what else?
5,143
940
I see a manual on Kubotabooks.com
BX2750D
kupitz
Mar 28, 2016
130
New Providence, PA
Disregard, I searched but failed to look at the sticky note at the top of this subforum and lo and behold there was a link to the manual.
Happy Snow blowing too all in the NorthEast dealing with the current Nor'Easter!
SidecarFlip
Banned
548
BX2750D
I especially like the chocolate smudge on page 11 at the bottom..... :rolleyes: Looks the same as my larger Lucknow. Grease fittings on each end of the auger shaft, oil, the drive chain with heavy oil (I use 90 weight gear oil, grease the Pto shaft slide halves and the U joints and thats it. I check my gearbox every few years tiomake sure it's full and not contaminated with water and that is about it,
