OMNI vs Heavy Hitch
gk527
Kubota B2650
Apr 6, 2017
140
Central Kentucky
I'm looking for a 3 point hitch system that will take a receiver hitch at the bottom for a bumper style trailer, and a receiver hitch pointing up for a gooseneck ball or whatever else I'd like to use it for. I would also like to be able to add weight to it for ballast.
I've been looking at the Heavy Hitch and OMNI products. I can get the OMNI about $60 cheaper. They look to be very similiar products online, however I'd like to hear from people who have used either of these products. Like and dislikes.
Or any other options out there.
http://omni-mfg.com/-OMNI-Combo-Imatch-with-Integrated-Weight-rack-P1341078.aspx
https://heavyhitch.com/store/
gk527
Kubota B2650
Apr 6, 2017
140
Central Kentucky
No one?
I've searched the forums and have read some reviews from as far back as 3 or 4 years ago. Just looking for some fresh perspective.
RonBoyBX25D
B2650, LP Grapple, Bro-Tek spacers, QH, Box Blade, Landscape Rake, RB, and 1560G
Aug 1, 2015
477
Minneapolis, MN
I went with the Omni transformer hitch, works great and built very heavy. Call and talk with them and you will get taken care of.
bearskinner
Sep 1, 2014
925
238
N. Idaho
This is a bit different than what you are looking at, but I use a quick hitch a lot as I switch from the land plane, cultivator rake and tow hitch. An inexpensive QH from HF ( $79.) and I picked up the A frame ($69. On amazon) with a 2" receptacle for tie balls. I also gave a 2" piece of box tubing about 28" long with a long 3/4" bolt that I can stack lifting weights on for quick removable ballast. Just another idea, something to think about
JackJ
BX1870-1
Mar 14, 2016
264
Indiana
I purchased the Omni combo hitch about a year ago, though a version without the weight bracket, and I've been very happy with it. Very solidly built with clean, uniform welds and good paint (powdercoat?). I remember looking at lots of different options, but liked some of the optional add-ons available for the Omni, particularly for log skidding in my case.
No experience with the Heavy Hitch.
4,059
I like this from OMNI for a BX.
I didn't want something on the 3ph.
gk527
Kubota B2650
Apr 6, 2017
140
Central Kentucky
I purchased this one from GenY
https://genyhitch.com/the-hitch-store/three-point-tractor-hitches/gh-824/
I have an older model that does not have the additional receivers under the corners. So far it has been a beast. Pulling trailers and skidding logs. Though I don't think is is set to directly take weights. But with all the extra holes you could easily mount something.
That's a nice one, but it's a little more than what I'm wanting to spend.
SLIMSHADIE
Kubota BX25D
Apr 10, 2013
445
Eureka,IL
Rcw you need to talk to Hodge for some stabilizers, those turnbuckles are old school. His stabilizers make turnbuckle minutes into stabilizer seconds!
4,059
Yeah Slim, I've considered Mark's stabilizers often.
I only use a box blade and a subsoiler, so hasn't been much of a problem. Little fluid film helps the turnbuckles.
Honestly, would go for a QH first, but both my implements need re-working first. On the list....
