Omni Mfg receiver hitch.
dwk121
BX1870 fel,54" MMM, ballast box. 3ph triball trailer hitch.
Jul 4, 2013
81
United States Falling Waters WV
Just received my omni mfg 3pt hitch. The fit and finish is wonderful. The paint is pretty darn close. You just can't beat this for 50 buck plus 20.00 shipping.
armylifer
Mar 26, 2013
1,958
702
Thurston County, WA
If you have never towed with a tractor before, you should be very careful that you do not lift the trailer tongue too high. If you lift it too high there is a danger of flipping the tractor. Be very careful when you start the pull and watch to be sure that the front of your tractor does not lift. Use low range and do not just mash the go pedal. Bad things can happen suddenly and you want to be sure that you have as much control as possible.
2,210
army - brings up great points too, might ought to look in a chain to limit up travel....
