Old rotary cutter
138KV
L2800
Feb 25, 2016
Lane , Oklahoma
The blade support is bent and the bottom seal is leaking and needs to be replaced. I can't find any gearboxes that have this type of output shaft. Do I need to throw this old mower in the scrap metal bin ? Any help would be appreciated. Image1465736892.037697.jpg
7,650
What brand is the gear box? You can probably purchase the shaft and seal. Then it would be as good as new.
138KV
L2800
Feb 25, 2016
Lane , Oklahoma
There are no markings or make on the gearbox and it is aluminum. The big problem is the blade holder is bent. I'm going to attach a picture of the blade holder. Image1465757456.144989.jpg
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
Gambrills, MD USA
If you have your own lathe, and welder and cutting torch, you could cut out the center of the blade holder, turn it down, and weld up a new blade holder...
NAH, the price of one of surpluscenter's, or agrisupply's makes that obsolete... You might save the gearbox and holder, if you are of a mechanical bent...
One thing, measure the hole pattern, and ask about it, prior to ordering a new gearbox and blade holder/stumpjumper.:D:D
138KV
L2800
Feb 25, 2016
Lane , Oklahoma
I used a hydraulic outrigger on a service truck once before to straighten the blade holder , first large rock and I'm right back where I started. Thanks for the replies. I probably need to pull some of those rusty $20's from my wallet and get a new mower. :)
