Old Rhino SE5 cutter ?
tater pop
64
Maud texas usa
I have an old se5 rhino and I found a stump or it found me and I bent one or both blades. Now here is my question,will another blade fit my rhino say king kutter Howse or another type?
BigG
Sep 14, 2018
1,953
774
West Central,FL
Try Tractor Supply or Rural King or maybe the feed store, auto parts store. Match the old to a new blade and you should be good to go. Do not forget to check the wear of the bolts and replace if needed. Some will tell you to replace the bolts every time you change the blades.
Double check the slip clutch if your mower is so equipped and adjust if needed. If you have a shear bolt I would replace it with a new grade 2 bolt. This is to prevent any more damage.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,289
183
Coyote Flats,Texas
You could try calling RhinoAg to determine if they still offer blades for the SE5. Have you checked for blades with one of the Rhino dealers in your area? I remember when Servis equipment Co later name changed to Rhino was located on Singleton Blvd in Dallas.
800-446-5158
