oil overfull - looking for advice
netspyder
L3010HST
Jun 9, 2025
19
Missouri
i bought this l3010 last year, and when i bought it, it had a new engine oil filter and the current hours were written on it. i'm 99% sure i checked the oil level before i paid for it, and it looked fine... my plan was to do a full service on it this spring, but when i double checked it, i only had like 50 more hours on the machine so i said "maybe not". i do not have any history on the maintenance on this tractor. got to my brother's today after dragging it down the highway may an hour or so and when i got there the oil was halfway up the dipstick (the dipstick is probably 36" long and the oil was 6 or 8 inches past the full mark) even after a wipe and plunge. i'm not freaking out just yet - i'll let it sit at my sister's overnight and check it after work tomorrow.
my question... is there a way to tell if there is hydraulic oil in the engine oil? does it separate if you let it rest? if the pump seal was leaking, it'd have to be significant to make a difference in a 10 gallon hydraulic tank, and i've had a hose burst and replaced some hard lines, so i can't say if i'm losing any fluid for sure. short of pulling the pump and replacing the seal (let's face it - if you pull the pump and don't replace the seal at that point it's likely you need a helmet to keep you from licking the windows anyway) is there a way to identify that 'yes, this is the trouble'?
6,787
Could be hydraulic or fuel contamination. Possibly both
I would start by draining it back to proper level and monitoring it and the hydraulic oil level.
JasonW
725
469
Al
You sure it’s the correct dip stick? Messicks shows the dip stick for that model a total of 14”.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,648
2,239
WestTn/NoMs
When that happened with my L35 the problem was a leaking fuel lift pump diaphragm. That seems to be fairly common.
