Oil drain plug
3,094
Should be two - either side of the front wheel drive shaft that splits the oil pan.
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
1,248
1,130
Amsterdam, NY
Engine oil (qty 1), transmission oil (qty 2), or front wheel case oil (qty 2, 1-left and 1-right)?
The operators manual has what you need, you can get it HERE.
Make sure you clean any fillings off the magnetic plug.
4,269
Asian Owners Manuals are notorious for erroneous English translations.
For example, the instructions “to drain” the transmission oil…. is complicated by unnecessary verbage…. such as ..” place an oil pan underneath the transmission case….”
Trust me on this. To drain the transmission…. A drain pan beneath the transmission is COMPLETELY UNNECESSARY. When you remove the drain-plug….. the fluid will drain out just fine!
You’re Welcome.
Shawn T. W
Dec 9, 2024
868
1,574
SW Missouri Ozarks
If it's anything like my L5030 ... Should be two ... One on each lower lobe of the oil pan which the drive shaft goes between.
