Oil Capacity
ttfo
B7100 HST, RTV 900
Oct 3, 2012
88
Custer, SD
B7100 hst old. The user and service manual says 4 qrts. Not sure if that included the filter.
I ran the motor for about 5 min. drained the oil, replaced the filter and put in 4 qrts. I check the oil stick and it showed over fill. I checked the dipstick to see if it was the correct one . it is.
I then again drained the oil, NOT the filter, added 3 qrts and it was good.
has anyone have info on this?
Thanks
7,234
Thanks
You got it right the second time.
Oil Change 101
Never add the full amount before checking the dipstick on any engine or transmission.
Caden
1979 B7100
Apr 16, 2026
249
125
Mine is right at the full mark with a little over 3 including filling the filter. No idea what the manual calls for.
3,058
Dipstick tells the truth........ most of the time!
Butttttt............. the dipstick CAN lie too - the little rubber stopper can move along the stick - so be aware of that !
whitetiger
Nov 20, 2011
3,670
2,087
Kansas City, KS
My L2501 has a 6qt capacity.
I have yet to put over 5 quarts in during an oil change.
If you could remove all the oil, it would hold 6 quarts, including the filter.
Kubota publishes the "dry" capacity, not the oil change capacity. They included a dipstick for refilling capacity.
Trash Panda
L2501
Feb 18, 2022
271
262
Wyoming
Yes.
That is indeed the point I was trying to make. Possibly a bit underwhelming on the delivery on my part.
ttfo
B7100 HST, RTV 900
Oct 3, 2012
88
Custer, SD
i did compare thee dipstick, including the rubber. sound like from others that itis a 3 qrt + filter.
Thanks
