Oil and Temp guages on my tractor
sandtractor
B8200, front end loader, Ganon, backhoe(non-Kubota)
Jul 15, 2011
12
Prescott, AZ
I have a B8200 that I want to put oil pressure and water temp gauges on. Haven't trusted idiot lights since the day they came out.
Any suggestions as to fittings on the engine block?
Thanks,
Terry
WinnieCouple
L245DT, razor brush hog, small disc, double bottom plow, 5' Turfline Box Blade.
Aug 1, 2011
117
Hico, Texas
I just found the post on a temp gauge so that's taken care of.
Terry
So, where do/did you put your sending unit for the water temp?
where did you locate the gauge...?
(people love a good follow up.. with PICTURES.)
just sayin.
sandtractor
Jul 15, 2011
12
Prescott, AZ
WinnieCouple,
Haven't actually put the temp guage in yet. I'm known to my friends for doing things "terry time" which is getting it done between now and when I die. What I was referring to was a post by kubotasam on 4/24/11 showing a setup for the upper radiator hose that he apparently found on ebay. I'll be going that route.
http://www.orangetractortalks.com/forums/showthread.php?t=4145
Terry
