Off setting 48" Rotary Mower
marrmanu
B2620 3pt chipper, box blade, post hole auger, custom 3pt chain box with hooks h
Jan 16, 2021
159
109
usa
Has anybody offset their 3pt rotary mower, or any reasons why this might cause issues?
Thanks Mike
Caden
1979 B7100
Apr 16, 2026
314
181
I'm a little confused. Do you mean offset it like just center it more to one side of the tractor?
In that case, the only issue I see is a slight but more stress on the U joints but the main hindrance to that is the 3 pt arms rubbing the inside of the rear tire. Not sure how wide your tires are set apart.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,196
1,181
E.
Yes I do on much larger tractor though.
It's easy and done all the time. Just find a suitable offset / side arm mower arm that matches your tractor and cutter.
You're going to be very limited due to the size of your tractor though. I think titan makes one for the bx.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,978
2,357
Western MT
I think the PTO shaft length could be an issue. They make pull behind mowers that offset. I think I would look into getting one of those to offset. Fwiw, I have one but rarely offset it to pull behind my Polaris Ranger.
marrmanu
Jan 16, 2021
159
109
usa
Thanks all for the input.
I have looked at a 3pt offset flail mower, however I just don't have that much to do to justify the expense.
I will definitely look at the pto shaft length issue. I have offset my box blade before, and yes the tire rub issue is something to keep and eye on.
Thanks again Mike
