Just replaced the pressure plate, friction plate and throw out bearing but am getting some rattling/spinning noises from my clutch on disengagement.
At times it is catching when I change gears.
I thought it was a clutch travel adjustment issue and have adjusted settings several times; this works for a little while then the problem returns.
I split the tractor again expecting the worst but everything looks ok
There did seem to be some fresh wear evident on the the shaft spline
Especially considering I had only run it for maybe 2 hours since rebuild.
However the friction plate still slides along the shaft spline just fine and there are no burrs.
The spline was a liitle dry when I took it out
I put a bit more grease on the pilot bearing and also on the shaft spline and the friction plate spline . I have retightened the flywheel and will realign the plates with the flywheel.
When I installed the new clutch I was pretty careful to line up the discs with the flywheel using the protruding shaft as the alignment tool.
Anyone got ideas on likely cause.
