No Lift
jsweeney
Kubota B8200
Dec 13, 2025
17
Florida Panhandle
I'd remove the filter and clean again. someone must of added a product they learned about on the internet to "improve wear and long life".
I had the same tractor, bought new in 1985, and somewhere along the line I got a hair brained idea to add something to the transmission oil. I got the same results. I cleaned the filter at least 2/3 times and eventually added a canister filter to the hyd. system.
I remember calling Kubota, I think in Houston, to talk to an engineer to figure what I needed. That was way before OTT.
Good luck getting it solved. That is a nice sized, all around tractor.
Small bubbles in the fluid are not normal.
From the diagram above I highlighed in red the places air can be sucked in. It may be best to replace the hose and clamps since a small hole in the hose can also cause air to be sucked into the pump. I believe all the others are a sealing washer but they can be a copper or a rubber (encased in steel) so not sure which you have. Get new from the dealer and replace. Clean the surfaces and make sure there are no large scratches on the surfaces.
If you drain the new fluid out into clean containers you can reuse the oil. I would suggest using paint strainers when draining and then filter it through a filter before using it again. Perhaps a fine micron filter that fits on or in a five gallon bucket would be better like these bags that might work really well.
or these that sit on top of the bucket
on edit = added photo I had forgotten to add
I drained fluid again and replaced o-rings #8 and hose #3. Strainer was clean this time but did spray with brake cleaner and used air to blow out. Still no lift. The pump sounds like its cavetating. Will replace o-rings #6next.
2,963
While you are changing the o-rings you can also ”prime the pump” by putting some hydraulic fluid into the top opening of the pump. I would recommend leaving the banjo bolt out and pouring oil through the opening in the tube marked #1 where the bolt is installed.
The oil may drain down slowly since the oil level might be below that level. The coating of oil on the gear teeth in the still help the pump pull oil into the pump. But I would try to start the tractor soon after you get it back together to give it the best chance of pulling fluid.
7,003
A gear pump is self priming once filled with oil. If it loses prime after sitting its defective.
2,963
But it also won’t hurt anything and could possibly help if it has sat static for a long time with low oil level.
jsweeney
Kubota B8200
Dec 13, 2025
17
Florida Panhandle
Well I've done all of the above still no lift. The pump will growl for a second or two and the lift will raise an inch when that happens then nothing for 5-10 seconds then it growls again for a second or two and the lift raises. It will continue this until the lift is all the way up. The growling continues in the same way when completely raised. Lift drops normal when put in lowering position then when put back in raise the same happens. ?????
7,003
This is a very simple circuit.
Have you checked for oil at the outlet block?
Have you verified the directional vslve on the outlet block is in the correct position?
jsweeney
Kubota B8200
Dec 13, 2025
17
Florida Panhandle
Yes. I removed the "A" port and started the engine and a gush of fluid maybe a 1/2 cup came out then nothing. Shut engine off and repeated with same results.
jsweeney
Kubota B8200
Dec 13, 2025
17
Florida Panhandle
It acts like its sucking air from some where. Probably just gonna get a pump kit, o-rings and seals, and rebuild it. I found out the lift has been inoperable for about a year. It has a finish mower on back and thats all its been used for all its life. Its a bushhog brand finish mower not brush cutter.
jsweeney
Kubota B8200
Dec 13, 2025
17
Florida Panhandle
Where do I find the serial number on this B8200E. I have found the metal plate thats attached on drive side of transmission housing but it doesn't have the serial# on it. It's a 1986 year.
7,003
A pump kit is not going to fix your problem. If its bad you need a new pump.
Do a little diagnosis before throwing money at it.
Remove the hose clamps (4) and rubber connector (3) on the suction line and drain the oil into a bucket. Start the tractor and use your thumb to test for vacuum on the suction pipe
2,963
If you do feel suction and want to be sure the pump will pump from a bucket to bypass the tractor intake piping you can see this thread for a description of how to use PVC pipe as an intake into the rubber hose. (The pictures are now missing). This was set up to suck oil out of a bucket and dump it out of the transmission drain. But you could remove the connection at your test point A (port “A” as you called it above) and catch the fluid from there.
If the pump is working properly it will pump several GALLONS PER MINUTE so don’t run it for very long or you will run the bucket dry and damage the pump.
jsweeney
Kubota B8200
Dec 13, 2025
17
Florida Panhandle
Thank you sir. Yes I want to make sure whats wrong. Don't want to buy when I don't need to. I'll try this.
jsweeney
Kubota B8200
Dec 13, 2025
17
Florida Panhandle
Thank you Russel for this idea also.
jsweeney
Kubota B8200
Dec 13, 2025
17
Florida Panhandle
Thanks everyone for the help. After cleaning the strainer 5 times I have lift.
Only problem now is no charging. Any trouble shooting tips greatly appreciated.
2,963
Glad you got it operating. You may want to replace the strainer with a new one in the future.
As I understand it your tractor has a dynamo and a regulator. The dynamo can be tested.
See this thread for details about dynamo and testing it (If it has two wires). If it has three wires then post back
jsweeney
Kubota B8200
Dec 13, 2025
17
Florida Panhandle
Mine is different from that one. I do have a dynamo but its in like an alternator not like the picks in the link. Mine has a water pump also, The dynamo on mine has two wires and as I was testing it showed 30amp ac at 2600-2700 RPM. Is the regulator testable or is it to be replaced when dynamo testes good?
Merry Christmas!
