No dash lights,no crank
Maxxsam
2002 BX22MLB
Jun 17, 2026
New York
I just lost a rear axle seal on my 2002 BX2200MLB. Pushed the seal back in place, put some sacrificial hydraulic fluid, drove it 100 feet in to my garage, drained the old fluid out , and picked up the seals for both axles, bought the super UDT fluid changed the spin on filter, changed the engine oil and filter. I was feeling great, turned the key to start the engine, and nothing. No dash lights when the key is turned on, no flashers or headlights, no crank, obviously. I know the battery is good, I hooked up the charger anyway, it was at 90%, now it’s at 100%. Is there anything I could have accidentally hit while doing any of the above service? I did jack the machine up and had it on jack stands, but I didn’t hit any linkage or wires, that I know of. I was mindful of where I placed the stands. Can anyone suggest where to start? I checked to obvious fuses right at the battery location, they are good.
whitetiger
Nov 20, 2011
3,568
1,996
Kansas City, KS
Clean the battery cable ends and check the slo-blow fuse next to the engine oil filter.
