No A/C
Garristl
M 4070 tractor
Sep 11, 2018
Mt. Hope Alabama
Hey Guys, I have M4070 cab heat/AC 4x4. I have checked all my fuses and all is good. How ever there is no power going to my A/C clutch. My low pressure safety switch omhs out to be good. It also has 12 volts going and coming from it. If you put a jumper wire on the battery to the clutch it starts working and cooling. but I can't see why I have no power is getting to clutch with all four fuses good.
Any ideals?
Thanks
cowdog
2,560
if you bypass the LPS ...what happens then?
If you measured the continuity.....that says you just have a closed loop - but it might provide enough amps to start that clutch!
Can you place the same jumper at different point in the circuit to bypass each piece?
Jim L.
853
155
To troubleshoot this easily you need a Workshop Manual (WSM) for your model. It will have wiring diagrams to help fault isolate.
It is likely that there is a compressor relay, a pressure switch(es), a sensor for evaporator icing, and a control amplifier. These are the components to check out using the WSM.
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to the OTT forum Cowdog. You came to the right place to get answers.
