Looking at purchasing my first larger Kubota. Have it down to the M5-111 4WD but am unsure on a few things - could use some advice. Will be used on +/- 125 acres of land to mow, put in food plots, move gravel, etc. -- fair amount of hills.
1. unsure of to get the HDC12 or the HDC24 transmission and why??
2. seems adding a 2nd rear remote/valve will be sufficient and then adding a 3rd function valve up front just in case for the future??
3. If I order the 12 or 24 speed its my understanding that I dont need to select adding the 540/540E PTO option and lever/switch as this come Standard on the 12 and 24 trans. models..??
4. unsure on the 84" round back bucket or the 84" High Capacity roudn back bucket??
Here's what I have spec'd out: (opinions on anything missing I might need?)
--M5-111HDC24 - 4WD Tractor with 24 speed, Hydraulic Shuttle & Cab
--Front: 12.4-R24 on 11" Rims Titan Tru Grip Lug
--Rear: 18.4-R30 Titan Hi Power Lug
--2nd Rear Remote Hydraulic Valve
--Front Load (quick attach)
--84" Two-lever Quick Attach Round Back Bucket
--Third Function Valve Kit for Cab
--Dual Speed PTO Kit (540/540E)
--Heavy Duty Front Weight Bumper Kit and 10 suitcase weights
--Drawbar Clevis
--Grille Guard PNF
--Air Ride Seat Suspension Upgrade Kit
--Instructor Seat Kit
--Rear Window Wiper Kit w/Washer
--Electric Defogger/High Cap. Alternator Kit
--AM/FM/Blue Tooth Stereo
Yes, I know cant use the front weights at same time as the loader...
thanks in advance for help in deciding which way to go and why....
--Drawbar Clevis
--Grille Guard PNF
