D DrHz Member Equipment L35 Jun 8, 2026 30 1 8 TX Aug 5, 2026 #61 TheOldHokie said: The proper way to test the pump is with this test setup. Dan Click to expand... Ok Dan that is a great looking setup. My assumption is that the flow is as above and you are using the valve to create resistance to increase the pressure?
D DrHz Member Equipment L35 Jun 8, 2026 30 1 8 TX Aug 5, 2026 #62 PoTreeBoy said: I'd clean and inspect it first to make sure it's in proper order. Could be a broken spring or trash. You could do more damage by cranking down on it. Click to expand... Good point, will do. Got to drain the stupid oil out of first when I get back. Then I will pull that out and inspect it.
TheOldHokie Well-known member Lifetime Member Equipment L3901/LA525, G2160/RCK60, G2460/RCK60 Apr 6, 2021 13,107 7,391 113 Myersville, MD windyridgefarm.us Aug 5, 2026 #63 Yes - standard test setup as described in the WSM.
