Newbie question, are jd and kubota's cat1 compatible?
sumking
kubota L2502-526, RTR1250tiller, sgc0660 grapple, Box Scraper, Landscape Rake,
Nov 4, 2023
38
canada
I might buy a used jd sb1164 snowblower because of the price, but I'm not entirely sure it will fit on my L2502?
2,871
The CAT 1 is compatible and/ or CAT 2 and so on..... and there are adaptors to make cat 1 fit cat 2 and so on.
even the PTO shafts are compatible ..... until you find the one maker that decided to do something different - very rare.
But that JD model should fit fine - you may need to MAKE sure the PTO shaft will be long enough or SHORT enough to work as it should ......... a worst case scenario, the SHAFT is a bit too LONG and you raise the 3 point up, and BAM - the rear housing breaks , so be careful there. IF you must cut the shaft - look up how to cut BOTH pieces.
YOU PTO power on that machine is at the bottom of the scale for that blower btw....... you may be underpowered a bit!
3,671
I’m thinking that Hokie means the telescoping Drive-Shaft might be too long… not the tractors’ PTO shaft.
hodge
Nov 19, 2010
2,958
528
Love, VA
Welcome to the forum!
Category 1, 2, etc is a standard. Any tractor that is cat 1 rated can use cat 1 implements. There can be some variations, like the PTO shaft length mentioned and the width of the mounting frame. What is standard is the link pin/pivot ball size. Cat 2 implements will use bigger diameter link pins than cat 1, cat 0 uses smaller pins than cat 1, etc.
sumking
Nov 4, 2023
38
canada
Today I carefully measured the rear details of 2502 and 3205. It’s a stupid way, but they are indeed almost the same.
Yes, in terms of just passing power output, I can only bet that it won’t be full of snow every time.
sumking
Nov 4, 2023
38
canada
Don’t laugh at me, I just found out today that the POT axis can be retracted, haha
