New Tractor: Failed 3rd function hose/adapter
Ben Dow
Kubota L3302HST
May 14, 2026
Benton City, WA
I have 10 hours on my new L3302. While using the grapple, the 3rd function hose started to squirt fluid when closing the grapple. I have attached a picture of the source of the leak, which shows a bulging o-ring. Could this have been operator error? Any other potential causes? I have already sent an email to our dealer with pictures/video but it is too early to expect a response. Any thoughts are appreciated.
6,228
Looks like it need a new o-ring. Failing at 10 hours, probably just didn’t seat quite right when installed.
Possible operator error? No.
7,001
Thats an ORB fitting that was not properly tightened.
10,763
There are mutiple Third function kits the dealer could have used.
So to say the O-ring used would be a real guess on anyone's part.
Loosen it up reset the O-ring in it's slot then retighten the fittings.
7,001
Well I will guessg with some confidence :)
If thats an ORB fitting as it appears the o-ring is a 900 series.
#906 for a -06 fitting
#908 for a -08 fitting
Dont try to make something else work.
