New to the Forum and Need Kubota knowledge
PwaMatt
B2150HST
Hello all, I have a Kubota B2150hsd.
Four wheel drive and hydrostat. I am wanting to run
A log splitter off of the hydraulics of the unit and am having a hard time, getting information and understanding it.
I have been a mechanic and fabricator most of my life but this I cant wrap my head around.
I wont be using it hard, just what I cant split by hand.
The tractor doesnt have a loader but has the valve on the side with the 3 connection ports. Which are I believe pressure, neutral and return?
Can i plumb a valve and hoses into it for the rear hookups?
Can I just put pioneer fittings in and run it straight off the side.
It has the directional valve wired into position.
And its my understanding that if I hook up to the tractor the it will work as a pump but the 3 point will no longer function?
Any advice would be great and thank you all.
PwaMatt
B2150HST
I see by looking at the hydraulic schematics of the priority valve that a factory loader would connect to 3 ports. The splitter has an open center valve mounted on it.
Which ports would I or could I connect to to operate the unit?
PwaMatt
B2150HST
Also can anyone tell me the size and style of fitting I would need to thread into the priority block for attachments?
My nearest dealer is over an hour away so it makes it hard.
Thanks again
5,335
First just so you know:
A hydraulic log splitter on that system is going to be incredibly slow (low GPM) about a 1/4 the speed of a normal splitter.
The block on a B2150 will be Power out in front and Power beyond in the rear.
The fittings should be BSPP.
https://www.discounthydraulichose.com/9002.html
LorenS
B2150HSD, Land Pride AT2572, Koyker 120 FEL
Mar 22, 2021
34
Thank you Wolfman, this is a good start on the information I need! Thankfully got lucky on the "Search" function. I bought a used Koyker 120 loader, and am finally trying to get it plumbed up - still not sure what fittings to install so nothing blocks access to the pedal, but at least I know the thread type.
