new to forum and tractors
Farr
24
erin
HEY... I'm in the process of getting a loan and want to get a 2013 B2620. I know I want the FEL, mid mount mower 60" deck, and the hay bale spear. Those things I'm sure of. I live in upstate NY, I have 5 acres, 3 cows, 1 min horse. Are there any other things that I should consider before buying this tractor??? I am almost 60 and this has been a 5 year journey wanting to buy this type of tractor. I can't believe I'm almost there... this will make life so much easier. Thanks guys...
2,582
Is it a new tractor or used????? If used I would buy new and take the ZERO % loan, and get more goodies! If from dealer - have them load your tires FOR you ......if not - load them later. Will need rear ballast box too!
Farr
24
erin
HI... All I know is that it has 0 hours on the tractor. It is from a dealer and they said the tires would be filled. Plus I will ask about the ballast box.
2,582
If you are financing it, get all you can get for ZERO %%%% - shoot get something you "want"......like a toothbar, grab hooks, have them do all of that.
Most dealers will knock off a lot of $$$ as you buy more.....and the difference in 23k and 25k aint all that over 4-5 years....... I aint 60 yet, but I know how much fun it is TO GET WORK done and not bust your a$$ doing it....these tractors are cheap when you compare to what it CAN do and WHAT TIME and hassle it saves you !
we need some pictures!!!
5,443
I second toothbar and hooks - first 2 things I got.
A box scraper would also be nice!
I moved a lot of stuff with mine last spring, and probably will repeat this fall grading the driveway.
Farr
24
erin
Thank you Hokie for the info. I went to those links and found what they are. Thanks again
