New Orange Owner questions
Nospamattack
L2900
Jun 8, 2019
Yoder, Indiana, USA
Hello,
As stated, I am new to orange tractors, I recently bought a l2900 with the intention to use it as a mower and an occasional driveway grading. I have had green tractors all my life and I must say I am very impressed with my new purchase! That is one stout little tractor. So, on to my question. My experience with the position control levers is that they are usually very easy to move around, my green 5510 can be moved through the full range with one finger.....now my l2900, not so much. I have to put alot more effort in to it....more that I think is normal....but again I never had an orange tractor...any thoughts? I have checked my speed knob, check for any grease points...again I am not new to tractors just new to this one.
Thanks.
jmg32975
US
Welcome to orange!
I don't have any experience with that particular tractor, but I'm sure there are many here who do.
I would guess that you're correct that it shouldn't be difficult to adjust the position control for the 3pt. My L3901 is very easy to slide the control lever up and down, however there is enough resistance that it stays in the position that it is set to.
Sent from my SM-G955U using Tapatalk
6,298
Do you have the Operators Manual?
If not get it at Kubotabooks.com
I'll send you a link to download the WSM (aka Service manual).
Probably what is happened is if it's sat for any time the resistance washers have rusted up and are not sliding, a little shot of PB blaster might loosen it up, if not you can loosen the lock nut, then loosen the second nut to get the lever to move easily. ;)
Nospamattack
L2900
Jun 8, 2019
Yoder, Indiana, USA
Wow, thanks for the helpful responses. Jmg32975, thanks for the confirmation. North Idaho Wolfman, I downloaded the operator manual, thanks for the link. I will jump in this morning and work through your suggestions. I look forward to the Service Manual Link. I will update once I solve this issue. Thanks again everyone!
Dchemphill1
L3901HST, brush hog, L525 loader, rear blade, forks and bail spike
Jun 9, 2016
92
24
Fort Calhoun, NE, USA
I am an owner of the L3901 and the L-M-H adjustment arm has gotten easier over time. If it feels like won't move, try lightly stepping on the F/R pedal and then shift to the desired range. Mine moves much easier between L and M now, I am not sure I have ever used High range...live in the hills.
Congratulations on your new tractor...they are tough little tractors.
Nospamattack
L2900
Jun 8, 2019
Yoder, Indiana, USA
It turns out this garage queen only ran a snow blower in the winter and stay parked in the summer. The previous owner actually cranked the nuts down on the lever so it would never get moved inadvertently. I took North Idaho Wolfmans advice, check and loosened the nuts and now, it like butter. Thanks everyone, this is such a great and positive community.
jmg32975
US
That seems reasonable if that was his only real use for it.
Glad it was an easy fix and happy tractoring!
