New Member.
ksandrew
B7800,L4740,M5040
Dec 18, 2011
Albany,Ga
Hi folks.
I am new here and learning. I own a B7800 that I have had since 2003, great machine used for mowing and roto tiller. Now has 350 hrs on it.
Just purchased 200 acres and the B7800 just did not cut it. Purchased new L4740 and am learning all about it.
I am amazed at what the B7800 will do. 6' disc harrow, the three furrow plough would not work due to the fact that the rear wheels would not go wide. Used the 3 furrow plough on a 8N and it worked fine. Connected it today to the L4740 and it is dream to operate. I am learning about all the fancy stuff on the L4740, cruise control, H-DS, no bog down etc.
I do not have the owners manual on the L4740 so am having to figure it out.
BTW the dirt is a light loam, (Norfolk Loam) so not hard on the tractor.
I am contemplating purchasing a 14' spring tine harrow, any thoughts.
Ken Andrew
Kubota_Man
BX24, Rear blade, Front blade, Snowblower, 54" MMM, Box scraper, Landscape rake
Dec 25, 2010
953
Kellogg, Idaho
Welcome to the neighborhood :)
While I don't know much about your Kubota, there are alot of folks on here that do and are more than happy to share their knowlege.
You are correct my little Orange Wonder continues to amaze me all the time :D
cabu
Kuno B1-15 (B1502DT)
May 24, 2009
736
Germany, Oyten
Also a warm welcome to you.
You sound entusiastic. I hope your Kubotas gives you a lot of fun and every evening you will be pleased about the work you have done together. ;)
carl
ps
Photos ??
TripleR
Sep 16, 2011
1,911
SE Missouri
Welcome to the forum, the L40 Series is a really nice tractor.
Sorry, I can't help you on the spring tooth harrow as our soil is a mix of clay and heavy ground and they just bounce off, we use the heavier duty harrow behind a disk or incorporated into a field cultivator.
bcbull378
GL3830,fel,brush hog,pallet forks,disc,gannon,auger,springtooth,plow,drag,ripper
Sep 6, 2011
579
32
Ventura Ca
First welcome to O.T.T I have a L3830 and farm in Ca and I have a 10' spring tooth harrow and my tractor pulls it fine and we farm heavy adobe soil. I have found that my L3830 will pull anything that our D2 cat will pull in our soil conditions. Good luck Dan
