new member
steve l
2 m9000,9540 all cabgmd700 kuhn 605m vermeer,r23a vermeer rake,468 jd baler,
Dec 29, 2010
77
bullard,texas 75757
hello,i am new to this forum,so bear with me.we have 3kubotas we use regularly(2m9000 1m9540)and l3650 used for bushhogging etc.we use the 9000's to pull 605m vermeer roller,the other we pull an r23a vermeer rake and 705 jd rake.the 9540 is used to pull gmd700hd g11disc mower.the 9540 would get the hydraulic fluid boiling hot,between 275 300 degrees,talked to kubota and they said it was normal(hahaha)i was mowing with batwing and the grass on the rear end housing caught fire.carried in and they discovered faulty valve inside the housing not letting fluid bypass properly everything that was burned and the valve was fixed under warranty.throwout bearing started making a bad sound,carried it to shop,they said clutch pressure plate and throwout out had turned colors because of heat,replaced everything under warranty@1800hrs.so if anyone else is having this heat problem feel free to contact me.oh yeah the a/c is much better in the 9540.happy new year.
steve l
Dec 29, 2010
77
bullard,texas 75757
Welcome! Aren't ya glad for the warranty service from a good dealer?
yes i am.i wish that everyone who has had a warranty issue(myself included)is this lucky.the dealer who performed the repairs was athens tractor&equpment,kevin martin service manager,very good people.they also replaced the clutch and rear main seal in one of our 9000's,this past summer
fj40dave
Sep 24, 2009
425
257
Yelm, WA
Awesome.....
It's great to hear a good report on a dealership!
I "Googled" 'em...here's a link if anyone is interested in doing business with 'em!
http://www.athens-tractor.com/
steve l
Dec 29, 2010
77
bullard,texas 75757
i have one issue with the 40series tractors that i dont like is the 3point lift.it wont pick up high enough if i get the top link adjusted to pick up a roll of hay or mower it wont go down low enough.i have moved the pins in the lower lift arms and it dont much good either.i think the lift arms are to short .any help out there
stuart
B7001 with loader & tiller, 3 point hitch and 4' rear blade
Aug 9, 2009
280
Aldergrove, BC, Canada
It might be a bit expensive, but you could try a hydraulic top link. That might be enough to give the extra range you need.
