New Member...G5200
DoctorMud
G5200
Oct 11, 2025
Louisiana
Good evening all. New Member here from swampy South Louisiana. First off what a great resource you guys have put together here. I hope to give much as I get. Thanks to all.
In 2016 my wife passed away unexpectedly and because of the memories that haunted me I moved off of our 13 acre homestead while retaining ownership. I had pretty much abandoned the place for nearly 10 years, only visiting occasionally to see how felt.
This year I decided it was time to move back to the home we built together and return it to its splendor in her honor. Its been nearly 10 years since the place has been mowed or maintained in any way. So first things first, 13 acres is going to require a machine. So I started looking around for something when a close friend approached me and told me that he had an "Old Kubota" in the back of his shop that had been there for about 10 years sitting. I asked if it ran to which he gave the normal response "It was running when I parked it there." He's keenly aware of my sense of nostalgia so when I asked him how much he wanted for it, he told me "Man, you want it to keep for yourself to clean up your place?
Tell you what, you bring a trailer and come get it and its yours." So I went to take a look and sure enough it was a mid 1980s G5200 with the mowing deck intact. It looked rough and was covered in dust, but the price was right and I needed a good project to work on since my retirement as an engineer in the oil and gas industry for 25 years. So I took it home.
I immediately found this site and have been lurking here for several weeks reading up on this machine. I bought a new battery, the electric fuel pump was seized, bought a new one. The wiring harness was a little hacked up but I got a schematic and rewired what was necessary to hear it start. The starter was stuck so I gave it a dose of penetrant oil and a tap and it zinged to life. It turned over pretty good, glow plugs were warming but no cigar. I opened the breeders and cracked the fuel lines to the injectors for thr next 2 hours tried to ge it to show some sign of life. And then "put put put put". It sounded like it was running on 1 1/2 cylinders but as I bled the air out it sounded better and better. So now that I knew it didn't have a rod sticking out of the oil pan i jumped on it and pressed the hydro drive pedal down and it pulled me across the driveway. I engaged the PTO and although it sounded like a 7th grade drum rehearsal, it spun up the blades. I spent the next several weeks with a lot of reading this site, cleaning it up, going over it, drained all the juices and replaced all the filters.
Bought new belts, checked the fuel system, electrical was charging, I greased everything, sharpened the blades and started running it through its paces. The first thng it did was began to overheat. I shut it down and serviced the cooling system and found the thermostat housing COMPLETELY stopped up with rust and oxidation. I replaced all the hoses and flushed and flushed and flushed, each time I ran it the little D600 engine ran better and better.
I got the cooling issue resolved pretty painlessly but I noticed a vibration that I knew wasn't good for the machine. I investigated the rotating gear and noticed the propeller shaft had about a 3/16" wobble on the transmission end. I pulled the shaft and found a bastardized coupling type apparatus that someone put on it as a "repair", eliminating the fiber vibration damper disk and leaving the splines only engaged into the engine coupling about 1/8", and beginning to show signs of stripping out. At $130 for the disk, I decided I would fabricate one instead. I am an enginer after all. So I made a mold, used layered fiberglass cloth and JB weld to create a new one.
Precisely machined it out and drilled the holes. I spaced it out so that about 3/4" of splines were ingaged on the engine end, put it all together and BINGO, vibration eliminated. The radiator hoses, especially the lower 3 piece hose was a real PITA until I decied to pull the radiator out to give myself some room. I made the mistake of eliminating the little pipe bolted to the block and when i started it up it leaked oil from that bolt hole like it had been shot with a .44. So out came the radiator once again and did it a second time, putting the little pipe back where it was.
The mower deck works, bearings all pretty good, seals all intact but the deck itself is pretty rough. I understand that I can get a deck from a newer model "G" and with some small mods make it work. Anything anyone can point me to on that subject would be helpful. Its really a tossup as to whether it can be patched or needs replacing. Im going to start searching now, but I know original decks are scarce. After first running it, it seemed a little anemic on power so I took my IR thermometer and tagged each of the exhaust ports, finding the middle one noticeably cooler than the others. I was going to run compression tests on the motor, but the more I ran it, the better it got until its making as much power as it should for 1200 hours. Interesting little project to say the least.
I could never have done it without this resource. Thanks to all who contributed, and I plan on using this site whenever necessary. Whenever I work on it I'll do a writeup to share with the community. Thanks again... I gotta go mow some grass!!
Pic of T-stat housing...
4,168
Welcome aboard sir.
Sounds like your pretty talented, so you should fit in well here.
Lots of good info (and talent) on this board. (y)
Hugo Habicht
G1900
Jun 24, 2024
911
1,285
Ireland
Hello,
welcome to Orange Tractor Talks and congratulations on your tractor and getting it running again (y)
22R
89
31
GONZALES, La
Welcome and you are right you can learn and save alot of frustration reading on this site. I am just south of Baton Rouge and have a 1992 G1900. I actually prefer the boxy look of your generation but they seem very closely related below the surface. You enjoy your home and Kubota Sir.
22R
DoctorMud
G5200
Oct 11, 2025
Louisiana
22R, post: 816907, member: 40975"]
22R
Thank you sir. Geaux Tigers!! I'm just across the Basin from you in St Martin, raised in Lafayette. I own some property over in south Livingston Parish on the Tickfaw River just across the bayou from the Tickfaw State Park. I stayed on the river in an RV while attending LSU in the early 1990s when Tiger Baseball was dominating Omaha.
What's the model number of your mower deck on that G1900? I believe that machine has a deck that can be modified to fit my old machine...
22R
89
31
GONZALES, La
22R
[/QUOTE]
Cajun Country !! Love it. I actually ate in Henderson yesterday and then hung out about a hour at the Basin Landing.
My deck is the 54” one.
Do you have or know someone with facebook? Facebook Marketplace has old kubotas pop up from time to time. You just have to be wary of scammers.
I will keep a eye out for a G 5200/6200 and G1800/1900 deck for you and let ya know through here if anything pops up
cliffboyer
L3301 w/LA525 loader, G5200 mower w/RC48 deck, Kawasaki 610 Mule, DR mower
Nov 30, 2017
260
60
Southern IL
Welcome to the forum.
I bought my G5200 20 years ago. Great machine. But the decks are a weak link, they rust badly when not kept clean. I did some patch work about 6 or 7 years ago, but the metal is really starting to get thin. Pin holes starting to really pop through. The machine is a keeper, so bout 3 years ago I scored a really nice complete deck along with almost all the hardware to convert to hydraulic lift. Paid $1300 for all that (and about 10hr round trip). Only paid $1700 for the mower! But having 2nd deck to swap when the time comes is worth it to me.
Battery location is a poor design. Some folks have cooling issues because of this. But I've never had any. Keeping radiator clean is a must.
Nearly 1900 hours. Very stout & reliable engine (Hey, it's a Kubota!). Had new water pump on it when I got it. I replaced starter 15 years ago. Dyno bracket & air filter bracket failed from vibrations. Scored Kubota replacements from Messicks. Only oil leak ever was from valve cover gasket. Easy fix, but still seeps a little from the 3 hold down bolts. New crush washers would fix that. Heating the old ones with a propane torch & dunking in water helped...but didn't quite do the job.
You get yours sorted out, you'll have a grass eating machine.
7,027
Welcome to the forum. I may have some new parts that fit that machine, like mower blades and rollers for the deck.
