New LX 3310
nbryan
Jan 3, 2019
1,438
951
Hadashville, Manitoba, Canada
I find it hard to believe the LX3310 doesn't use glow plugs? I've never heard of a Kubota tractor that doesn't, except the M8 which doesn't have a Kubota engine. And even so, the intake heater design should be equally effective - all the Cummins diesel pickups use an intake heater and no glow plugs, and they start as well as anything. Definitely has nothing to do with being turbocharged...the Grand L higher horsepower models and MX models have turbos and glow plugs.
Ya no glow plugs, uses air heater.
Seriously, for the few added HP and nothing more I wonder why buyers go for the 3310 over the 2610 when the 3310 simply adds turbo and the requisite pita DPF systems.
All needing operator attention and are added systems subject to failure compared to the 26 hp emissions-control-free engine.
Any B50 or LX series owners out there that couldn't function without the few added HP?
So glad I went with my B2650 not B3350. Sure, may be a little slower at chipping up larger stuff, or break through brush stands faster with the bush hog, but not much more.
Now I'm hearing the 3310 has issues with very cold operation, harder to start, too cold for regen cycles.
No thanks.
SDT
Apr 15, 2018
3,706
1,425
It might be done because these motors have a turbo on them. Not sure, just putting this out there.
B3350 with turbo has glow plugs as does L6060, M9960, etc.
SDT
Apr 15, 2018
3,706
1,425
No thanks.
35% more HP is an enormous increase.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,995
2,364
Western MT
It sure is, but how much of that is more usable with the same weight tractor? I'd personally consider the L3560LE or L4060LE instead of a more deluxe model or L3901. Each has significant more weight and in the respect of the 3560LE and 4060LE can be upgraded to a much more powerful loader.
Where do you want to stop?
nbryan
Jan 3, 2019
1,438
951
35% is enormous indeed, but I come up with 27% increase not 35%. Please show me your numbers and math.
My numbers are 33HP vs 26HP.
So 33/26 = 1.27 which tells me it's a 27% increase.
Or even 26HP with 7HP increase:
7/27 = 26% increase looked at that way.
35%? How?
7,017
35%? How?
Try your math with stated PTO (19.5 vs 27) hp. I believe that's what SDT was referring to.
SDT
Apr 15, 2018
3,706
1,425
All of it on the PTO.
I, too would consider the L3560 if I wanted similar HP, but the comparison was between the 2610 and the 3310.
SDT
Apr 15, 2018
3,706
1,425
Bingo.
Even 27% is an enormous increase in a tractor of this size.
B737
LX3310
Jun 9, 2019
2,022
2,205
...I wonder why buyers go for the 3310 over the 2610 when the 3310 simply adds turbo and the requisite pita DPF systems.
because the increase in PTO HP is significant, it is unmistakably noticeable when doing PTO field work verses using a B2601 (same PTO HP as 2610) or BX.
wut? lol the light comes on, and you continue to work.
ok?
it doesnt.
B737
LX3310
Jun 9, 2019
2,022
2,205
cold soaked single digits & teens (°F), no problems in any aspect of operation including starting, running or regen. It was updated by the dealer but no issues beforehand either.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,750
4,635
PEI Canada
Plenty of people post their problems. How many LX3310 owners or any other model post that everything is working perfectly? I guess I will.
So far, my tractor has worked flawlessly. With that being said I do keep it in a unheated garage and winter has been more quite mild. My biggest reason for moving to the LX3310 was the extra pto hp which was a huge improvement over the 2610. Would a L35/40 be even better for some? Yes, but not for me.
DPF so far has been a none issue. 3 regens in 125-130 hours and I just kept working although I had to bump up the rpm in one of them slightly.
SDT
Apr 15, 2018
3,706
1,425
LX3510 and LX4010 to be introduced any day.
Both have new and quieter HST.
Snowman7
LX3310 535 loader, LX2980, RB2672, FDR1660
May 20, 2020
406
312
Boyne Falls, MI.
3 regens in 125 hrs? Mine has avg. every 16 hrs
S-G-R
Jun 17, 2020
1,750
4,635
PEI Canada
I normally operate around 2000 rpm unless blowing, tilling, or mowing, then it is 2300-2400
First regen was at 18 hours. Lower rpm loader work. Next one was at 118. Probably 110 tilling/mowing and the last 8 loader work. Next one was around 15 and more loader work.
Snowman7
May 20, 2020
406
312
Boyne Falls, MI.
Wow, I hope I don’t have a problem
Snowman7
May 20, 2020
406
312
Boyne Falls, MI.
You must have some seriously flat ground. I have a 60” rfm and sometimes that is too wide, lol
S-G-R, Did you have the recall done on the fuel system? I have not, my dealer has not been in this area. I am almost two hours away and I do not have a trailer.
