New kid in school, seeking advice.
7,958
My snow packs to ice when run over due to unusual environmental conditions created by the tree opening (warm enough to pack, not warm enough to melt), so it's more desirable to blow on the way down the drive and plow (scrape) on the way back, running over as little snow as practical.
I have wondered (for other situations) how well the forward-facing 3-point blower (reverse blower) works.
I think it really depends on the type of snow you typically get. Up here the snow is quite dry and powdery, but even still, I try not to drive on it for the very reason you mention. The inverted blowers are very expensive so it would be nice to know whether or not the results are going to be acceptable, but this is a decision I'm hopefully years away from having to make.
I ran a front blower (BX5450) on the BX25 for five winters, and typically had the RB1572 rear blade on the back but rarely used it to move snow. I was blowing snow on approximately 400 yards of gravel driveway, and although blowing gravel isn't much fun, it was a good setup for a small tractor. I use a hydraulic angle snow blade up front now, but that wouldn't have worked well on the BX due to the lack of weight and power required to push accumulated snow on either edge of the driveway. Blowing snow clear of the driveway was a better solution for that setup. These days with a combination of gravel and asphalt, a front angle blade for the gravel and rear blower (either type) for the asphalt seems to be a really good setup.
WI_Hedgehog
Apr 24, 2024
549
670
Milwaukee, Wisconsin, U.S.A.
Thinking about your comments and since I have a front-facing blower a better setup for me is probably to keep the front-facing blower and get a rear blade, that way I could blow and scrape in one motion.
7,958
If you invest in a rear blade, being able to offset the blade is a really nice feature to have, even if it's manual offset rather than hydraulic. I will say though that being able to offset, angle and tilt the blade from within the cab is the bee's knees. 😂
WI_Hedgehog
Apr 24, 2024
549
670
Oh stop, your posts have caused me to look at bigger Kubota tractors that I don't need on a weekly basis. :ROFLMAO:
Thanks to the patience of members here I'm learning about hydraulics and expect to do some fun fabrication later this year.
7,958
I have to tell you that I do the same. I look at M5, M6, M7 and M8 tractors on a weekly basis too! 😂 I'm really happy with what I have, and unless I win the lottery or start working for my brother I'm never going to own any of them. But it's always fun to look and dream.
Looking forward to seeing the upcoming projects.
WI_Hedgehog
Apr 24, 2024
549
670
OMG I'm not the only one! If I won the lottery there'd be a 60HP Grand L and M6L-111 parked in their own barn before Fall.
(And a few different types of wood processors.)
