New here.. 1630 FEL on B7100 not operational
lawn guy steve
Kubota b7100 /1630 loader
Sep 6, 2017
little rock,arkansas
Just purchased a B7100 4wd with 1630 loader $500. 1086 hours .Tractor runs great, loader not so much . I have drained all fluid and cleaned screen refilled with 3 gallons TSC udt premium . Zero movement .
The guy I purchased from said he had the controller apart to replace hoses and isn't sure they all went back correctly . Where do I go to get proper placement . Any information would be greatly appreciated . Thanks !
2,780
Re: New to site ,need assistance
ok....
lets get some more info.
FEL did not work when you bought it?
IF HST - does tractor move?
IF not HST- does 3 point lift?
I cannot help you with controller -someone will come back and ask about what type of controller it is.
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Welcome to the site, lots of good info and help from many experienced players.
Just a note for your next posts, please try to describe some of the problem in your title with reference to your tractor model.
So something like 1630 FEL on B7100 not operational, it helps get the right people to your problem.
You may wish to download the WSM (shop manual) and operators manual from here, you may need it. http://kubotabooks.com/AutoIndex/in...s/&AutoIndex=56b08f1cee1625ebe3d2f361f579c75e
Exploded parts diagrams can also be very handy and are available here
http://www.kubota.com/part/partsList.aspx
coachgeo
Nov 16, 2012
2,459
37
Southern OH
You may wish to download the WSM (shop manual) ....l]
THANK YOU FOR YOUR MEMBERSHIP and we look forward to being of assistance and look forward to your participation in many topics.
Massively agree with 100 td. Editing your title.
As you cruise there here note the READ ME atop each forum. They contain very helpful links ... such as to manuals that 100 td was kind enough to pull up for you.
8,546
Re: New here.. 630 FEL on B7100 not operational
First determine if the unit is powered by the on board hydraulic pump (located behind the injection pump), or is it powered by a seperate pump on the front PTO (IE crankshaft).
Is the model a self contained (has it's own reservoir) or does it share the tractors reservoir?
lawn guy steve
Sep 6, 2017
Hokie Tthanks for quick response ,not an hst tractor will move ,no problem there and yes the 3 point will lift . The controller no idea although i think it is Kubota .
lawn guy steve
Sep 6, 2017
100 td ,Thank you the down loads are going to be extremely helpful . I just need a 27 hour day to do my mowing and my tractor project .
8,546
Going to need some pictures of the supply lines to the FEL (both ends) to see how they have it hooked up.
lawn guy steve
Sep 6, 2017
I am going to have to the tech dept to down load pictures and they are in school at the moment BUT they will be headed that way .Thanks
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
While I expect something besides incorrect plumbing of your hydraulic lines is your problem (would be nice if it was eh!), I found this reference to you valve which may be helpful down the track at some point
<Have a Kubota B6200 diesel tractor with a B1650 front loader ... the controller for the front loaded got loser and loser. Went to a local shop and the sent me to call a used parts reseller ... no joy. So then went to the dealer and the the hydraulic controller wasn't available ... out of stock. So I went to the local rebuilder and they could not find parts for it. So it was up to me ... the unit is part number 27FABS6M1AB (was actually so dirty that I thought the number was 27FAB56M1AB), and was made by Victor Fluid Power, which was out of business in the 1980s. The people there opened under a new name, called Granite Fluid Power (www.gfpmf.com) but they sold off the 27FAB line to DanFoss. Then DanFoss merged with Sauer and now they are Sauer-DanFoss (www.sauer-danfoss.com) ... but they sold it off to QC Corp (www.qccorp.com). Contacted them and found out that the valve is available for ~$700 as their part number 156B2126. Ouch !! So I then asked for a re-build kit, called a Detent/Float kit ... and that part number is 156B8566 ... and it's under $70. Delivered the parts to the re-builder and for $120 to them, now have a new controller. No leaks ... tight ... works great>
