J jagee94 New member Equipment bx2200 May 5, 2025 4 1 3 billings missouri May 5, 2025 #1 would a bx 2200 be ok pulling a 60" finish mower? my belly mower needs work and i can get a finish mower pretty reasonable. Thanks
GeoHorn Well-known member Lifetime Member Equipment M4700DT, LA1002FEL, Ferguson5-8B Compactor-Roller, 10KDumpTrailer, RTV-X900 May 18, 2018 6,337 3,687 113 Texas May 5, 2025 #2 if the grass isn’t too tall…say less than 14”
J jagee94 New member Equipment bx2200 May 5, 2025 4 1 3 billings missouri May 5, 2025 #3 thanks, i bought one used for $640. i think it was a good deal. Reactions: 1 user
B Bee-Positive Well-known member Equipment BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box Nov 16, 2022 511 510 93 Amsterdam, NY May 5, 2025 #4 That sounds like a great deal if it's in fair condition. Change the gear box oil, even if the seller said he "just did it". Like GeoHorn said, and you'll hear the it bog down if you're mowing to fast. You have 16.8 HP at the PTO so you should be OK. Reactions: 1 user
J jagee94 New member Equipment bx2200 May 5, 2025 4 1 3 billings missouri May 6, 2025 #5 Bee-Positive said: That sounds like a great deal if it's in fair condition. Change the gear box oil, even if the seller said he "just did it". Like GeoHorn said, and you'll hear the it bog down if you're mowing to fast. You have 16.8 HP at the PTO so you should be OK. Click to expand... What oil is good for the gear box? thanks for the advice
D D2Cat Well-known member Lifetime Member Equipment L305DT, B7100HST, TG1860, TG1860D, L4240 Mar 27, 2014 14,669 7,152 113 40 miles south of Kansas City May 6, 2025 #6 80W-90 gear oil. Reactions: 1 users
