New guy needs help b8200 hyd problem
burgettw
Kubota b8200
Sep 13, 2010
Robertsdale,AL
Hi everyone I just purchased a b8200 2wd and the hyd 3 point is not working and I can not find where the filter screen is...searching on the internet I find it saying its in one place then another so if anyone could help that would be great! Thanks!
burgettw
Kubota b8200
Sep 13, 2010
Robertsdale,AL
http://www.messicks.com/partdetail/67800-37120.aspx
I found a picture of the filter but just cant find on the tractor where it would go...does anyone have a snap shot of where this filter belongs?
Nevermind I just found a post on here I did not see the other day that Palomar had cracked his gearbox and said it was right above the strainer and I can clearly see where he was talking about now and I could not get that bolt off so I guess I will have to get some heat to it or something....
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,140
139
Hardisty, Alberta
Please Don't use heat!!! Get a proper fitting socket and a long "cheater" and have a go at it. If it has never been off it will be VERY tight. You might have to jack up the tractor to get enough swing on your wrench. Be careful replacing it also, it is quite easy to cross-thread it then you ARE in trouble!!
Ed
burgettw
Kubota b8200
Sep 13, 2010
Robertsdale,AL
Well I think I have figured out my problem I got the bolt off and my filter is completly clogged up to the max...so I plan to cut the mesh filter off the bolt and put a inline filter so it will be easier to change next time.
