New BX 1880 ?LA211?
n4k
9
HUEYTOWN
I'm looking to buy a new BX1880. I have an old BX1880 that has a LA211 loader on it. Dealership is telling me that loader will not go on the new one. Is this true, or can it be modified to fit? Thanks!
4,900
I don't know but.... anything can be modified to fit...
I'd look at online parts and compare part numbers for frames,axles,hoods and other 'key' components to see what's different between the old vs new tractor. Is it a 'mechanical fit' problem or a 'hydraulic' one ??
You should post how 'old' your 'old' BX1880 is, especially the serial number. Perhaps you only need a 'new' bracket ? it's hard to believe a manufacturer wouldn't 'reuse' old part
6,364
Looked it over and it looks like the BX1880-1 has a completely reworked frame, and hydraulic system.
So trying to attach the old LA211 loader would probably require way too may mods to be a fruitful adventure.
The old BX1880 with a loader attached will fetch quite a bit more money on sale than just a plain tractor.
And honestly the LA334 with an SSQA adapter is an all around huge upgrade!
n4k
9
HUEYTOWN
Thank you both! I'll leave it on the old one for sale, and debate if I want to sink an extra $5k into having one put on the new one. Again, much thanks!
JeremyBX2200
BX2200
Aug 3, 2020
466
436
Indiana
I have the LA211 on my BX2200. It has 3 hoses that attach to it from the tractor’s hydraulic system. I believe the newer BX setup has 4.
Is there a specific reason why you are replacing your older BX1880?
Im not sure what you use your BX for, but having the loader on mine is one of the main things that makes it 100 times more useful than just a mower.
