New B7300 owner questions
Nordski
B7300
Sep 26, 2018
Winthrop, Wa
I just bought a 1997 B7300HST. I am interested in adding a post hole digger. What do I need to know when shopping for them? I have seen adds online that say "fits compact, cat 1 & cat 2" tractors. Which of these sizes is the B7300? Is that all I need to know when adding implements?
Is there a 3 point hitch size difference when looking for rear attachments?
Any other advice is appreciated. Thanks.
6,443
The three point on that model is a Cat I.
That's what you'll need to know to get the right setup. ;)
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to the OTT forum. You have come to the right place to get answers.
Congrats to you on your "new to you" tractor.
K.P.
B7300, LA272 FEL, B2650, 8160 Ballast, G2460G Mower, Danuser 20/40, Woods RB60
Aug 11, 2010
84
Cary, IL
The power take off horse power is rated at 12hp. Theoretically that means you don’t want to go too large with the hp requirements of the post hole digger. Having said that, I’ve been using a Danuser on my 7300 rated for minimum 20hp but I’ve been able to turn a 9” x 36” auger with no problem as long as I dig about 12” at a time and bring it back up to clean the hole. The 16” auger that also came with the deal is a different story. I can dig a 12” deep hole with little problem. After that it’s tough. Also, you want to tighten the swing arms down so there’s as little side to side movement as possible. Finally, keep a big pipe wrench and even an extension pipe in case you get stuck on a rock or root. With no reverse on the PTO, you need to manually back that sucker out. A real PIA but after awhile you learn to feel obstructions by the seat of your pants. Don’t hurry it and you’ll be fine.
My neighbor has a newer bota with 16hp at the PTO but his tractor hogs down with with my auger. Could be other reasons for that, I don’t know. He ended up buying a PHD with a proper HP requirement but the brand only has 30” long augers.
The 7300 is a great little tractor. Enjoy it.
