Hello all!
I'm a recent B6200 owner.
I don't know the year of the tractor.
Maybe someone can tell me what to look for.
However, a local dealer told me even the serial numbers might not tell the year.
Anyway..... wrongly assumed that I could let the unit sit outside in the winter and go out anytime and start it up expecting the front bucket to work.
Last January when temps were 20degrees F and lower, I found the hydraulics wouldn't work.
I assumed it was water in the fluid so I dumped out the reservoir.
Found the filter was all gummed up and cleaned that.
Then put new hydro-oil in from the dealer.
And it ran fine all winter and next summer.
This winter I went out on a 20 degree day and the bucket wouldn't work at all. So I'm thinking that the unit really needs to be kept in a heated space for winter use. Is that what most people do?
Also, I think I didn't follow the correct procedure for getting all of the oil fluid out. I think I'm supposed to raise the bucket and then drop the fluid out...or something like that. I hear that some people will use compressed air to blow out the fluid piping?
Where do I obtain information on how all of that is done?
Also, at this point, I've discovered the loader control is dry.
So I hoping there is a way for me to check if the pump is working.
Any suggestions would be greatly appreciated.
