New B6000 owner...what's this extra lever?
davesisk
Kubota BX1850 w/ FEL & MMM
Oct 11, 2017
52
Raleigh, NC USA
Ah, I spotted those holes/pins on the rear axle (did not check the front). If I think I need to widen it some more, than I'll look at those a little closer...so, thank you!
So, I did flip the wheels (tire thread is symmetrical)...This actually adds about 5" of width to each side, and was an easy change. Here's a pic of one flipped...note the difference in distance between the tire and fender.
And here's a pic with both flipped "dish-out"...it went from 37" at the rear tires to around 45" wide at the rear tires.
Here's some of the work I did with it today...moving a storage shed strapped to the bucket (after clearing and leveling the intended location), and lifting one side of the storage shed to remove the casters that were attached underneath...enjoy!
The hydraulics seem quite strong, and they don't leak down when the engine is off.
Cheers,
Dave
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,255
1,060
Williamstown Ontario Canada
Your tractor will be much more stable with the wide rear track.
When you first start out at a high speed with muddy tires, there is going to be a lot of muck in the air. :)
I suggest you make a rear weight for your tractor if you are going to be lifting stuff with your FEL. The front axle has no roll over resistance since it pivots in the middle. You are relying completely on your rear axle to keep your tractor off its side. When the tractor starts to go over under the pressure of the FEL and the rear tires are barely touching the ground because of the weight on the FEL, things will get out of control so fast there is no time to react. Certainly, as you commented earlier, getting a roll bar and seat belt is a smart move.
Your weight should be low in its construction so the effect it will have will greatly improve the stability of your tractor. Using a barrel is not a good idea as a lot of the barrel of concrete' weight will be above the height of your rear axle which means it will help turn you on your side rather than prevent it.
Dave M7040
davesisk
Oct 11, 2017
52
Raleigh, NC USA
...I suggest you make a rear weight for your tractor if you are going to be lifting stuff with your FEL. The front axle has no roll over resistance since it pivots in the middle. You are relying completely on your rear axle to keep your tractor off its side...
Dave M7040
Ah, good point about the pivoting front axle. :eek: I was thinking an old rusty barbell and weights that I have (from when I was younger and could actually lift them :p ) might be a good choice. Could very easily pickup the weight bar with the quick hitch when I need the weight. How much weight do you think I need? I've discovered the tractor starts to lift a rear tire at around 400 or so lbs, I think.
I have a small yard, so I rarely move fast...not too worried about slingin' mud. :)
Cheers,
Dave
davesisk
Oct 11, 2017
52
Raleigh, NC USA
One thing I definitely need is a finish mower for this B6000. I'm googling for any that might fit, either belly mower or 3 point mower. I've seen one youtube video with a B6000 pulling a Woods RM48 (must have had the PTO reverser on it?)...I've also seen mention that a Woods 304K was specifically made for the B6000, so I'd assume no PTO reverser necessary.
There's a place near me that has two belly mowers off Farmall tractors for cheap...they are both belt-drive. I could probably find a way to retrofit one of these to the B6000 (might take a little fabrication). I'd need a 90 degree PTO-to-belt pulley gearbox though (no mid-PTO on mine, and I see the shaft for a front PTO, but it doesn't extend out of the transmission that I can tell.) Any good ideas on a relatively inexpensive 90 degree PTO-to-pulley gearbox that might work?
Cheers!
Dave
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,255
1,060
Cheers,
Dave
A couple of other pointers. There are no brakes on the front wheels so if you have a heavy load in the bucket and travel down hill you wont have much braking available to you as the unloaded rear wheels just lock up. This is when 4WD is your helper. In 4WD, the braking of the rear wheels is transferred to the front wheels by the drive train where all your load is.
Nothing like steel for a rear weight. A nice piece of 3" thick plate!!
Any material, other than steel or iron, that is affordable weighs much less per cubic foot. Of course a few gold bricks would be heavier :)
I cannot find 3 pt capacity figures for your tractor. I looked at the B7100 which weights a few hundred pounds more than your B6000. The B7100 will lift about 1030 pounds on the 3 pt.
With that in mind I am thinking 300# would be adequate.
Dave
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,255
1,060
Cheers!
Dave
The front pto is actually coming off the engine directly I think.
Gear boxes. They can be very expensive.
Sometimes if you are lucky and creative you can reverse the direction of an implement gearbox.
By moving the input gear to the other side of the box, the rotation of the output shaft is reversed.
This type of gearbox is often on snow blowers and farm machinery. It is designed to be mounted with the "top" up or turn it over and the "top" is down. This reverses the gearbox rotation.
All of this is nice in theory but in practice, a machinist is needed and expensive.
Dave M7040
davesisk
Oct 11, 2017
52
Raleigh, NC USA
Yup, got it on the "downhill with a load in the FEL" thing. (I had an old Power-trac PT-425 for several years a decade ago...great little articulated tractor/loader contraption...did a lot of work at my home with it! I gained a few lessons about going down a hill with weight in the loader, although it's pucker-factor was a little less than a traditional CUT.)
So, I'm looking at the operator's manual, and I don't see the transmission oil dipstick...the manual shows it near the main shifter. I don't see one...maybe it's because of the creeper gearbox? Where the heck do I check the level of the transmission oil?
The loader has a separate hydraulic pump run by a belt from the engine, and it uses the right side of the loader frame as it's reservoir. That's a good setup...isolated from the transmission. There is a small crack in a weld in the loader frame near the top on the reservoir, so I need to figure out how to fix that (it leaks if I fill the reservoir too full, plus it might let water get in). I can weld...but I'd have to empty the reservoir first (just got this thing, don't want to set it on fire just yet! :rolleyes:). I wonder if something like JB Weld would be enough to fill that gap and close up that crack? Maybe some other expanding sealer? Or am I just gonna have to weld the crack (with fire extinquisher nearby)? Any thoughts?
Cheers!
Dave
3,602
Not familiar with your tractor or the creeper gear, so I can't be any help there, but your loader appears to be a B219. Pics don't show enough for a positive ID, but the B219 does use the right hand upright for the reservoir. If it is, the fill level should be 4" below the breather opening; maybe the crack is above that?
I would weld it if necessary, but that's just me.
davesisk
Oct 11, 2017
52
Raleigh, NC USA
Thanks for the post...yup, looks like a Kubota B219 loader, downloaded the manual for it.
So, on the right angle gear for a PTO-to-pulley, this might work (flip it 90 degrees so the output shaft spins faster instead of slower...I'm assuming it's two bevel gears instead of a worm gear)...this would also make the output shaft and pulley spin clockwise (looking at it from the top). http://www.surpluscenter.com/Featur...r-PHD-26-Post-Hole-Digger-Gearbox-13-1525.axd
Not sure a 44hp model is needed, but might be able to find something a little smaller.
UPDATE: Ah...even better, gearbox specifically for a mower: http://www.surpluscenter.com/Brands...Gearbox-1-1-46-Ratio-Model-250001-13-1526.axd
Also, I'll bet a simple differential gear could be adapted to be a 90 degree gearbox...just lock one side.
Cheers,
Dave
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,255
1,060
Post a picture of the crack in the loader frame. If welding up a crack, the ends of the crack should be drilled first with a about a 3/8" bit. The idea behind this is that the crack is already past where you see the crack on a microscopic level and you want to remove the micro cracking.
Imagine a sheet of paper like you would use in a printer. It is hard to start a rip in the paper if you stretch it. Now put a small tear in the side of the sheet and pull again.Now it will tear much easier as the crack or tear was already started.
If the crack is a structural failure, you need to understand why it happened.
A plate over the crack may be better as it reinforces an area which has already started to fail.
Post a picture again of the creeper area of your tractor.
The gear boxes, whose links you posted for your application, wont work as their input speeds are limited on one to 540 rpm and on the other, 1,000 rpm so driven from your engine at 2,000 rpm wont last.
Dave M7040
davesisk
Oct 11, 2017
52
Raleigh, NC USA
Here ya go, Dave:
I did figure out that it's indeed a creeper gear...you engage it by putting the main gear shift in the middle between 1st and 2nd gear (there's an extra position down between those two), then that extra lever controls whether you're in low-low-low or low-low-high. The tractor barely moves...I can't see it being that useful, honestly. I recall someone posting that it's not as rugged as the other gears, even though it's a very low range. Maybe I'll only use it when I'm parking the tractor in the shed (so I don't accidentally knock the back wall out of my shed...it barely fits in there). :p
Dave M7040
If I added a 6T female spline and ran this off the rear PTO, it should work fine...right?
If I found a belly deck (not sure it'll fit with the loader frame on?), then mount the 90 degree gear box to the tractor rear, and run the belt forward to the mower deck. If it were a 3 pt mower, then would prob make sense to mount the gearbox on the mower deck, and run a PTO shaft to it instead.
The crack in the loader frame is on the inside (left side) of the right loader frame vertical post (same one that is the reservoir), and it's where the flat stock is welded to the frame (the other end of that attaches to the tractor frame). This is maybe 4 inches down from the top of the loader frame/reservoir, so it's not any dire emergency. (I'll get a pic next time I have it out...it's not low enough to leak unless I overfill the reservoir, and I'm not too worried about that flat stock braced breaking loose.) Why did it crack? Who knows...it's a 1973 tractor that has been beaten for 44 years. My guess would be a not-so-good weld from someone with a hangover on a Monday morning sometime in 1972. :)
I had mentioned a diesel fuel leak from somewhere...found that and fixed it (cracked fuel return hose). Also have adjusted the brakes (left side parking brake is now quite secure...right side doesn't seem to have enough travel, maybe I need some new brake shoes), and adjusted the clutch (there's now sufficient travel to shift smoothly...but, dang, ya gotta practically stand on the clutch pedal...I'm going to attach a big rubber wheel chock to the pedal so I'll have a little more leverage).
LOL. I saw sparks coming from under the left side of the hood yesterday afternoon. Say what? :eek: Turns out the pulley on the hydraulic pump had worked itself a little loose, and was just barely scraping a bolt on the radiator. Got the speed wrench (hammer...LOL) and tapped that back into position on it's shaft...all good now. Like I said, it's a 44 year old tractor...I'm expecting I'll have to patch up a few things along the way. ;) That said, I beat it pretty hard over the weekend scraping an area flat and moving a shed onto it...and I didn't manage to break it (yet..LOL).
Cheers!
Dave
davesisk
Oct 11, 2017
52
Raleigh, NC USA
I found a used belt-driven 46" mower deck locally for almost free. I snagged a set of bevel gears off Ebay for cheap (they came out of the differential of a 21.5hp lawn tractor, so probably OK with the torque, but not sure how they'll hold up to heat from higher speeds). Here's a pic:
The counter-clockwise rotating tractor PTO connected to the left side of this (or a similar) differential gearset will give me 1) a downward shaft that spins clockwise (looking at it from the top...attach a pulley to run a belly mower...correct direction for most mowers, right?), and 2) a shaft out the back that spins clockwise...so, this should give me a clockwise PTO plus a clockwise belt pulley PTO as well. Seems like a workable solution. I'll have to build a gear case around it that would mount to the rear of the tractor, get all the couplers right, etc.
Dave_eng...what do you think? Those steel bevel gears were designed to turn slow...will they heat up/crack/fly apart if spun 540 or 1000 rpm under load? Making the gearcase oil-filled would help with heat dissipation...how much oil? (Worst case, maybe I need to find a set of automotive differential gears...? And maybe put a slip-clutch on the shaft that connects to the tractor PTO so if the bevel gears do break or jam it doesn't damage the tractor transmission?) Even if this isn't the exact right set of gears, a set of differential gears sure seems like a good solution, and should be reasonably easy to find used/cheap.
Your thoughts appreciated gentlemen...
Cheers,
Dave
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,255
1,060
Cheers,
Dave
With differential gear sets, the challenge is stopping the pinion gears so the torque comes out one side only. Your idea of having both backwards and forwards rotating shafts seems difficult as in my mind you can only use one at a time or the pinion gears just turn and no power goes out the other side.
I have no experience in welding up differentials to lock them but the engineer in me says welding on heat treated gears does not lead to long life.
Others may have done this with great success for stock car racing on dirt.
The bigger gears you use the better as then you are reducing the load they see.
One of the really tough rear 3pt hitch snow blowers for your size of tractor was made by McKee for several tractor manufacturers including Kubota and John Deere.
The blower had two bevel gears to transmit power at 90 degrees to turn the auger sprocket.
These gears run totally un lubricated and in the open with just a simple guard to keep fingers out. They will be running again this winter.
This is a picture of the gears.
This is the blower those gears are on.
My closest friend has had a B7100 HST which he bought new in the 1970's
The blower is just about as old.
The blower was designed to run at 540 rpm from the rear pto but my friend has always run it at a higher pto speed of around 800 rpm (my best guess) and there is no problem at all with the bevel gears after all these years and at a much higher speed than the blower was designed for.
I think in the sort of "back yard," design like this, the key is providing a lot of support for the shafts holding the gears so under load the gears are not moving about as their shafts deflect.
Also getting things attached to the rear pto and the mower deck pulley are challenges.
Shear bolts in the pto shaft have been a very reliable way of protecting tractors from loads imposed by implements.
The shear bolt needs to go on the implement end of the pto shaft not the tractor end.
I think you want to have a pto shaft in this connection to your tractor. It is all too easy to have a design which unwittingly imposes a side or up or down load on the pto shaft and it is not a good practice to do this. You fabricate something with these gears and attach it to the pto. To secure it to the tractor you drill some holes and use existing bolts. A bolt is like a screw jack and the force it can exert as it is tightened can be very high and you really don't even notice this and suddenly there is a snap and the rear casting on your tractor has a big crack in it.
This is a photo of a repair to my mistake many years ago. No warning just a loud crack and a piece of cast iron on the ground. I felt sick to my stomach.!!
I am not certain if you have seen these rear pto reverser solutions but here they are.
Item D goes over your pto shaft, gears lower the output and reverse it if needed and then another shaft goes forward under a tractor.
This next image is not of a Kubota but a very old tractor. I think the owner has been very clever in his use of sprockets to reverse the pto direction.
Mower decks on more expensive garden tractors have gearboxes on the mower deck. Many of these tractors have reached the end of their lives with electrical safety switch issues etc but their mower decks are usually a heavier product than a cheap garden tractor would have. In my rural neighborhood there is unlicensed small engine mechanic. His yard is littered with the left over garden tractors.
He does not use the internet and it is a word of mouth business. I think there are these guys everywhere. Big box stores sell garden tractors, no one wants to fix them when they did not sell them, repairs are expensive and they are junked.
If the mower deck already has a gear box on it, it wont matter if the drive for it comes from the front or the back of the tractor.
Making a drive system to come off the front engine pulley also seems do-able for someone with your skills. Now you have a drive at the speed mower decks are designed for.
This deck was on a semi commercial garden tractor.
The engine had a double wide or two pulley system on the engine which dropped to a lower level using V belts. At the lower level under the engine a shaft , driven by the two v belts drove the mower deck gear box.
Lots of things for you to contemplate and look forward to hearing what you decide to do.
Dave m7040
davesisk
Oct 11, 2017
52
Raleigh, NC USA
Dave_eng...good stuff, thanks for the post.
Dave m7040
Let me clarify what I meant about the differential gears...I don't actually need the whole differential gear unit...the ring gear and pinion gear can be taken out of the mix. What's needed are those 4 gears inside the differential...the two side gears and the two spider gears (just like the pic I posted). The combination of those four in a suitable gear case with suitable bearings/etc would produce the clockwise output shaft rotations down and out the back. And yes, I think you're right...the case containing those four gears would need to be bolted to the tractor in some way that doesn't crack the castings, so thanks for that thought. A belt under the transmission pulling that down-pointing shaft forward might not be such a good idea...hmmm. Lemme think some more. :) What I'm envisioning is something very similar to "D" above, but with 2 side gears and 2 spider gears inside...one side gear is turned by the tractor PTO, one spider gear faces down and has a pulley on the end of it's shaft (so a belt can go forward under the tractor transmission), the other side gear sticks out the back with a standard 6T spline on it, and the other spider gear shaft points upward (but probably doesn't need a pulley on it, nor anything exposed).
It might be a lot easier to stick a hydraulic pump on the tractor PTO, and run hoses to a hydraulic motor mounted on the mower deck!
Question: Don't the PTO reversers that were made by Hub City bolt to the rear of the transmission case?
Cheers,
The other Dave
davesisk
Oct 11, 2017
52
Raleigh, NC USA
Found the dipstick and filler plug for the transmission...the filler plug is on top the creeper gear assembly, and the dipstick is hidden behind that assembly and various other mechanicals under the front edge of the seat. Presumably, it's in a different spot than the manual shows because of the creeper gear.
Dave
davesisk
Oct 11, 2017
52
Raleigh, NC USA
Another probably stupid question: Where is the alternator on the B6000 engine? I don't see one. There are two belts on mine...one goes from the engine crankshaft to the hydraulic pump for the loader, and one goes from the engine crankshaft to the fan (and presumably water pump). Is there an alternator spun along with the water pump? Or does the starter double as an alternator?
I also noticed there's an empty belt pulley on the engine crankshaft...was this what provided power take-off for a former front PTO?
TIA!
Dave
3,602
I believe your B6000 uses the same setup as the B7100. (and others)
There is no water pump, it uses a thermo-syphon system to circulate water, i.e. hot water rises & cool water falls. What appears to be the water pump is actually a dynamo, putting out about 48v AC, which is then converted to 12+v DC.
Odd, huh?
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,255
1,060
TIA!
Dave
On kubotabooks.com there is a WSM that covers B7100 and B6100 tractors. This is a high quality copy with clear illustrations and color illustrations to explain the workings of your tractor's innards. 335 pages of a wealth of knowledge. I highly recommend it.
Lil foot has it right. There is no water pump and the Dynamo is where you would expect a water pump to be.
Let me mention another detail. The thermo syphon system uses a whistle on the rad vent line as a way to tell you things are getting too warm.
You should look for it and make certain it is not full of mud from mud dobber flies which are prevalent in many parts of North American.
From the WSM:
This engine is water-cooled and is equipped with a radiator.
Water which absorbs heat in the crankcase and
cylinder head water jacket, is fed to the upper side of the radiator where it is cooled as it flows through the radiator passages before it is returned to the crankcase. This cooling is done by convection.
The key in this system is a 13# rated rad cap.
From the WSM the spec's on the Dynamo:
AC Dynamo
Nominal voltage . . . . . . . . . . . . . . . . . . . . . . . . 12 V
Maximum output . . . . . . . . . . . . . . . . . . . . . . . 10 A, 120 W
Rotating direction . . . . . . . . . . . . . . . . . . . . . . Clockwise, viewed from the pulley
Polarity . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Negative grounding
Regulator
Type . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Thyristor direct control
type
Nominal voltage . . . . . . . . . . . . . . . . . . . . . . . . 14.0 to 15.0 V
The dynamo has permanent magnets inside rather than electrical windings to produce a magnetic field. Then the armature of the dynamo rotates in the magnetic field and produces a modest output of 10 amps of single phase alternating current. Two wires leave the alternator carrying the AC to the regulator/rectifier where the AC is transformed to a nominal 12 volt DC along with heat which is why the regulator/rectifier is equipped with cooling fins.
On more conventional charging systems, the voltage regulator's job is to control or regulate the output of the charging system.
The dynamo system, which by the way is found on my 1981 Suzuki GS1100 motorcycle, has by its design an output which is not controlled. Its output is changed by engine speed.
Any power in excess of your needs is turned into heat. The rectifier/regulator has no idea of the state of charge of your battery. It just controls the voltage going to the battery. The regulator/rectifier turns excess amps into heat.
The V belts driven off the front engine pulley were used for front mounted things like snow blowers. Two belts were used.
Dave
davesisk
Oct 11, 2017
52
Raleigh, NC USA
Another question: Oil pressure light on my B6000 doesn't work. I've ordered a new oil pressure switch, and I'll just replace the (presumably) light bulb with an LED. Here's the question: Can I connect an actual oil pressure gauge to the oil pressure switch instead? If it's got enough output to power a 12v light bulb, I'd suspect it may be able to power an actual gauge too. Anyone know this answer?
Cheers!
Dave
