I have been looking at b3350 2016 . Is there any tire clearance issues with the rck60 or rc72 mmm front and rear tires. Wanting to add spacers for the rear.
I have the B2650 and in the book it says that the deck bump stop is equipped with extra spacers on the bump stop for use with turf tires for added clearance, mine is a 60 inch deck with R4's and does not need the spacers. Evidently the turfs most be larger in diameter and interfere when raising the deck. Bump stop extensions keep deck from raising to high and hitting tires.I am trying to recall on the tires. If you use the large R4 19x5 rears you can't use a MMM! Also according to the whole goods book wheel spacers are not compatible.
Pat
The B2650 does not use 15x19.5 tire package. Only the 3350 has them as an option! And if we revert back to the OP's title.....I have the B2650 and in the book it says that the deck bump stop is equipped with extra spacers on the bump stop for use with turf tires for added clearance, mine is a 60 inch deck with R4's and does not need the spacers. Evidently the turfs most be larger in diameter and interfere when raising the deck. Bump stop extensions keep deck from raising to high and hitting tires.
My deck installation instructions said exactly that.I have the B2650 and in the book it says that the deck bump stop is equipped with extra spacers on the bump stop for use with turf tires for added clearance, mine is a 60 inch deck with R4's and does not need the spacers. Evidently the turfs most be larger in diameter and interfere when raising the deck. Bump stop extensions keep deck from raising to high and hitting tires.
