My BX25 temperature gauge is broken and upon opening the dashboard, discovered the gauge is based on a stepper motor which had damaged teeth. That appears to be irreparable so I need to replace the whole dashboard. All Kubota parts sources say its obsolete and there is no stock anywhere in the US. Does anyone know who might have a BX25 dashboard from a tractor wrecking yard? I'm in the process of building a circuit to indicate HOT based on temperature the sensor voltage ( below about 3 volts) as an LED warning but wold rather get a new working dashboard. thanks
