Holy smokes I didn't realize I got all these replies already!
Couple of answers to various questions from above:
-The blades are not upside down and I'm fairly sure i got all the washers back on.
-I have been running the tractor at full throttle when mowing. The bx2200 doesn't have an RPM gauge so I run it full power so it has enough.
-There are ruts that run left to right in the picture with the worst circles. So that section of the lawn it rocks the mower quite a bit and I have had to run through that section slower than the rest of the yard.
The grass is still pretty short since we have not had rain in weeks. I water via the nelson tractor sprinklers on about an acre of land so i'm keeping it green but not seen a ton of growth since the last cut.
I think next steps are:
-pull the deck this week, get it propped up and I'll check the blades, make sure everything is tight and the bearings look good.
-I may even swap blades with a spare sharp set and run 2 to 3 passes to see if it improved.
-If not I'll move the scalp wheels down to be just above supporting the deck to see if that helps on the next few passes.
I'll probably not get to cutting before this next weekend so I'll update with my findings. Thanks again for all the advice!
