Need quick assistance Landplane build
L1802dt
L1802dt
Mar 17, 2018
31
Arnhem
Hey all,
I am on my way to the workshop to start a landplane build today.
Got everything sorted accept... I have never seen one up close haha.
My question I pretty simple. Do the scrapers (angle profiles) stick out underneath the sides of the frame? And if so, how far would be alright?
I always thought the bottom sides of the angle profiles were level with the sides of the frame but I have found an immage online where the interchangeable wearing blade sticks out. (See the pictures). I whas not planning to put the wearing blades on there. Or should I do that as wel?
Hope you can help me out guys! Thnx
greenacresnorth
L2501,BH77
Feb 18, 2018
175
29
Morganton,NC
depending on the brand it varies, Ive seen some hang down 1"-1.5", others that are 1/2-3/4" down. your are defiantly going to want some kind of hardened cutting edge, mild steel wont hold up for very long in aggregate.
9,997
I made mine 3 years ago and it works great.
My blades protrude about 1/2" or 13mm below the side rails.
The blades I made are AR400 or AR500 steel (very important) normal steel will not last a season.
They are fixed and non movable or replaceable, but no need as after 3 years of some hard work they still look real good.
L1802dt
L1802dt
Mar 17, 2018
31
Arnhem
Thanks guys for the advice. I am glad I asked ***128579;
Another question, I see some planes that got the blades under an angle/offset from the frame and some that are just welded at 90 degrees. At the moment I am still cutting the parts. What do you think? Offset or 90 degrees?
9,997
Most definitely an offset, does a much better job! ;)
bearskinner
Sep 1, 2014
926
241
N. Idaho
Heres a few pics. I borrowed Wolfmans land plane, ( red) and did the same as your doing. I made a slightly lighter version, as I pull it with my BX. I believe I spaced the AR500 blades down 5/8 inch below the side rails. It works great! Hope the pics help. A little Kubota Orange and a Kubota decal too.
Ike
Kubota L 3301, Farmall Cub. JD B. Ferguson TE 20
Jul 18, 2015
324
Mich
For cutting edges go to the county road commission and see if they have any wear bars off there grader blades. The ones I got had one side new and were about 4 inches wide by 8 foot long
bearskinner
Sep 1, 2014
926
241
N. Idaho
After spending the day planing my roads and trails, and actually making a couple new roads thru the trees, I can not imagine if I hadn’t used AR steel on the two cutting blades. The main gravel road and driveway were already like concrete. It took a couple passes just to break thru the surface.
What a difference it made on the small pot holes left from spring rains.
bearskinner
Sep 1, 2014
926
241
N. Idaho
Waiting to see some pictures of your progress.....
