Need m6060 parts for a wrecked tractor. Rear end.
Cindy
M6060
Jan 18, 2020
Custer
Looking for parts for a wrecked m6060. Rear end housing is cracked. What other tractors have the same rear end?
200mph
Mar 3, 2017
1,228
59
PA
ID the part that needs replacing in the one of the online illustrated parts drawings and then place the PN into messick's. The PN details will also have a section showing what other models use the same part number. This will help answer your question.
What makes it somewhat difficult to answer your question directly is I'm not certain where the crack is and what you're calling the rearend. I believe the main section between the wheels is called a transmission by kubota and axle cases bolt to the transmission. Perhaps a picture of the damage would help.
You might want to delete your duplicate post (if possible).
5,158
If it is the Transmission case (what they normally call the differential case), it was only used in the M6060's and the M7060's. ;)
