Need help on "Ground Point"-instrument panel.
Tooljunkie
May 13, 2014
4,150
No reason it couldnt be used as a ground point, just make sure the contact areas are free of paint and rust. Also run a jumper from that point to engine ground. Most instrument panels are isolated on rubber for vibration.
2,600
is that a washer under the bolt? or is that something else? Like TJ said - could be a spot, simply take your v/o meter out, touch the inside of the thread of that hole and ground, see if you have continuity. If so - clean all the mating materials to use.
rbrown7713
l1500dt
Mar 4, 2016
41
seffner, Fl.
See, this is why that I should have takes pictures. I think it is a ground junction, if I remember right and of course it could be used as a ground. I didn't want to miss the fact that it could be used for something else, thank you for your answers, Bob.
6,992
It's not a ground point, they didn't weld tabs on for ground point as it fails too easily, It's probably a mount for a regulator, relay, horn or something like that.
Can it be used for none yes, but I wouldn't, your way better off either adding a ground lug or terminal eye and wire to a large bolt in the cast like the clutch housing. ;)
rbrown7713
l1500dt
Mar 4, 2016
41
seffner, Fl.
Yes, mine is also an l1500DT, and thank you, so now I know. I wondered why my flasher was dangling on the wires, so I will mount it there, thank you. Bob.
billrigsby
Mar 17, 2015
1,023
208
Florissant CO USA 8213'
www.facebook.com
From the looks of my flasher there was a decrepit piece of rubber that should have been bolted to that position but with time and dryness it is practically disintegrated
Bill Rigsby
Florissant CO
1972(?) KUBOTA L-1500-DT
Great Bend M10 48" Front End Loader
Brush Hog 48" "Squealer Mower"
Atlas 48" Landscape Box
Rhino 48" Rear Blade
Draw Bar with 2" Ball
36" Sears Snow Blower (still to be mounted to the front PTO)
