marrmanu Active member Lifetime Member Equipment B2620 3pt chipper, box blade, post hole auger, custom 3pt chain box with hooks h Jan 16, 2021 150 106 43 usa May 24, 2026 #1 Just started using a little bit bigger brush hog this spring and noticed that on my properties hills I was losing traction. So I went to my Junk pile and came up with this. Reactions: 1 users
B Bee-Positive Well-known member Equipment BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box Nov 16, 2022 837 825 93 Amsterdam, NY May 24, 2026 #2 I PICK THEM UP AND PUT THEM DOWN! As Arnold would say... Nice use of scrap material. Does the bar clear the loader so you don't have to unbolt it every time, just take the weights off? And I gotta ask - is that a grill guard of some sort?
marrmanu Active member Lifetime Member Equipment B2620 3pt chipper, box blade, post hole auger, custom 3pt chain box with hooks h Jan 16, 2021 150 106 43 usa May 24, 2026 #3 Thx No the bar will not clear I think you are referring to the wood on the grill. Its my chainsaw scabbard. Reactions: 1 user
Caden Active member Equipment 1979 B7100 Apr 16, 2026 152 74 28 Virginia May 24, 2026 #4 Any reason you don't just leave the loader on an use that for front weight? Reactions: 1 user
marrmanu Active member Lifetime Member Equipment B2620 3pt chipper, box blade, post hole auger, custom 3pt chain box with hooks h Jan 16, 2021 150 106 43 usa May 24, 2026 #5 Easier to get around stuff. Reactions: 1 users
Runs With Scissors Well-known member Equipment L2501 TLB , Grappel, Brush Hog, Box Blade, Ballast box, Forks, Tiller, PH digger Jan 25, 2023 3,820 5,123 113 Michigan May 25, 2026 #6 Nice job sir! I am particiuralalry fond of finding “alternative uses” for otherwise useless things….. Here is “cloths dryer” idea that “I came up with”…. Reactions: 2 users
