ctmike
L 3750 DT with loader, brush mower, rear grader blade, box scraper, rear blower,
After doing some brush mowing for the first time with my new-to-me L3750 DT, I discovered a lot of tall grass had wrapped itself around the unprotected drive shaft for the FWD. I needed a razor knife to remove the grass and after I did, hydraulic oil started steadily dripping from the oil seal located at the rear of the driveshaft (underneath the transmission). I've drained out all the hydraulic oil, pulled back the sliding coupler and need to know how to remove the oil seal. Can I remove the 4 large bolts shown in the photo that bolts the gear case to the transmission and will this allow me to pull out the part to work on it on the bench? I know I need to order the driveshaft cover when I order the new seal. This was my first 4-wheel drive tractor and I never thought about the spinning driveshaft picking up the grass like that.
