Napa(don't) know how.....
5,182
I had an SUV and a van with the junk Walmart batteries. After destroyed battery trays, much corrosion and destroyed windshield washer pumps I had to give up. Yes, they replaced each leaking battery multiple times but the vehicle damage was on me. I agree on the cheap build and suspect that the Walmart buyers pressured the manufacture for every nickle possible. NEVER, NEVER AGAIN, not even a flashlight battery from this store.
YMMV........I have had nothing but good luck with the Walmart Everstart MAXX batteries.
WAS BANNED FOR NSFW PICS
5,157
Working on the SIL ‘62 Cadillac last month. Went into Autozone to get some light bulbs and I see their sign for tool rental. Asked them if they had a dwell meter for rent (I already new the answer) and the deer in headlights look that I got still brings a smile to my face.
You don't need a dwell meter to properly set the points on that engine. Once the engine starts, turn the Allen screw in till the engine just starts to stumble, then turn it the other way till it just starts to stumble, and then set it in the middle, and it will be correct dwell. Now you can set the timing with a vacuum gauge if you don't have a timing light.
Yooper
3901 LA525
May 31, 2015
1,670
821
NE Wisconsin
That would be a new trick for an old dog 😉. Actually, your method is the alternative in the manual. And I will not argue with you. I used to leave my distributor loose and turn it to tune it to the gas after every fill up. Back in the day with the venerable 350 Chevy small block. Gosh, I miss those days!
8,715
Were they over tightening the mounts and cracking the batteries???
Of course, I don't let them install anything for me including the battery.
will721
LX2610, Ford 2n, Ferguson TO20
Jun 6, 2023
179
187
Quad Cities Area
Now I'm out of date by several years now, but outside of imports or "boutique" all batteries were made by one of two companies. East penn and johnson. They are unofficial partners and they pretty much determine who gets what in what state based on whether they are east or west of the Mississippi. That also includes the fancy optimas, interstate, delco, all of them.
Battery construction at scale is not a perfect science, and at the end of the process they are broken up into batches depending on final output. The various brands then get to pick a batch, slap their name on it and go.
Past that usually what determines the lifespan is luck of course, but mostly how it was stored. Many walmarts for instance store them outdoors in shipping containers or aren't cycled properly hence their bad reputation. Nothing wrong with the battery itself just how its stored, so in some areas where theres a good store people have good luck with them. Others not so much.
The leaking Battery in question was probably the result of someone stacking batteries at some point. Likely at the store itself when stocking the shelves. Odds are they wouldn't recieve credit for it when sent back, and that in most cases comes out of the managers bonuses which is based on several factors including warranties. Still bad customer service at the end of the day, but might explain their motivation.
lynnmor
B2601-1
May 3, 2021
1,674
1,453
Red Lion
I too never let anyone install batteries. These were Chevrolets with the mounting clamp at the bottom which causes no problem with over tightening. The batteries had internal problems that caused them to cook out electrolyte.
