Mystery Pigtail
McBuck
L3560LE/LA555/RC1872
Oct 30, 2021
29
49
North Georgia
I found a mystery pigtail/plug on my L3560. It’s factory pigtail sticking out from the cab strut on the just behind my left shoulder. It’s about 4” long. What’s this for? Rear work light? I just had front work lights installed, but this was there from day one.
mtdave
L4060HSTC
Jan 3, 2022
23
If I understand your question right, I posted the same question recently and didn't find a definitive answer.
Here's the post I started:
WAS BANNED FOR NSFW PICS
5,152
Using a test light, see if it is hot all the time, or only when the key is in the run position. If on all the time, then you have to switch it to be able to use it. If only hot when the switch is on, then use it for a beacon or LED light. Not sure what fuse controls it, then short it out, and look for the blown fuse or start pulling fuses till you see which one controls it. All of this is based on general automotive wiring knowledge. If you are not sure what to do, then just tape it out of the way and forget about it. Dusty, giving basic worthless information for the past 95 years. Soon to be 97.
5,721
wiring diagram, if correct, will have it....
I don't know if Kubota is consistent with wire colors,that would help.
kubotafreak
Sep 20, 2018
1,049
395
Arkansas, US
Inside at the top left, center, right is defroster plug( may be tucked in headliner). Inside bottom, should be accessory power. Outside top is rear work light. Inside bottom right is accessory power.
3,500
It’s for a Top Secret Accessory costing thou$and$ that stops L3560s from going into auto-regen.
(sorry…couldn’t resist) :ROFLMAO:
Seriously, Kubota used standardized harnesses for crossing-over several models which had options which..if not ordered…had un-used/empty pigtaails.
