My Kubota was a dirtbag!
Kubota Newbie
M4500, New Idea Cut-Ditioner, JD 14T Baler, IH "Plow Chief" plows, Oliver Rake
Dec 28, 2010
533
81
Mount Vernon, Ohio
Nobody is an idiot, it's just that everybody interchanges two terminologies (back pressure and exhaust velocity) that aren't really interchangeable in terms of discussing engine exhaust flow.
Oil based or latex? ;)
BTW, mufflers generally speaking, are not a "restriction" on the exhaust system for their intended application and within the engines intended operating range. Cut one apart sometime and you'll quickly find that the total opening area within the muffler is greater than the combined open area of the engine valves as it is running. So there really isn't a restriction in terms of open area available for flow. The muffler "muffles" by causing the flow to change direction repeatedly, canceling the sound waves against each other and the internals of the muffler. All this changing direction reduces the "velocity" of the exhaust gas which is where performance gains, or losses, begin to be realized.
Technically speaking though, the "pressure" in the cylinder and exhaust system is higher than the surrounding atmospheric pressure from the moment the exhaust valve opens. That's why it's trying so hard to get out the end of the pipe, it's rushing out to try and fill the space where the lower atmospheric pressure exists. Just like air rushing in to fill a vacuum.
brokersdad
2001 Kubota L3010 w FEL
Oct 24, 2009
92
Had to look for this thread as I remember it from a while back. I definetley have to do something with mine because after plowing for 2-3 hours the smell is enough to make you sick due to it blowing back on you all the time :(
meanjean
Kubota MX4700
Aug 10, 2010
922
Hazelridge, Manitoba
I had put a 90 degree bend on mine.
Problem was I got a blast of exhaust everytime I got on/off the machine.
I've since chopped out the bend and added a cap, night and day the difference.
