My Kubota motor got damaged
451johnny
61
Stroudsburg
I have a Kubota B7001 with a 3 cylinder 16hp diesel D650 motor ( damaged ) and I have the chance to purchase a D722 or a D600 diesel motor and I'm wondering if any of these motors will fit my tractor I would appreciate any help in this matter...johnny
dlundblad
G5200, L2501, ZD1211
May 16, 2009
503
10
IN
Re: my kubota motor got damaged
Get the biggest one you can fit.
My G5200 has the D600. Its not low on power at all, but I can***8217;t imagine it being in anything bigger.
451johnny
61
Stroudsburg
would a D722 OR A D600 fit my kubota
my Kubota B7001 has a 3 cylinder 16hp diesel D650 engine that is damaged and I have the chance to buy a D722 or a D600 both are also diesels and my question is ( and I know some minor modification has to be done ) can these engines be installed on my tractor and are they some what similar to my original D650..?? would appreciate any help ..johnny
5,271
Neither one of those two will work, too many things are different.
You need a D650, D750, D850, D950. ;)
I have a completely rebuilt D850 if you want something really nice to put in it.
451johnny
61
Stroudsburg
my Kubota B7001 has a damaged 3 cylinder 16hp D650 diesel engine and I have the chance to get a replacement a D722 or a D600 are these 2 engine some what similar to my original D650 and can they be installed with little modifications..?? johnny
4,430
Re: would a D722 OR A D600 fit my kubota
Where are you located? North Idaho Wolfman, on here, has/had a completely rebuilt engine for a B7100 listed on Buy Sell Trade a couple of weeks ago. Was all Kubota parts with no shortcuts.
Might send him a PM. You can ship things with Fastenall at about 1/3 of regular trucking cost, so you can save there.
451johnny
61
Stroudsburg
oh I forgot to mention that i'm from Stroudsburg PA ..and I called a few of those places ( buy sell trade ) and mostly all said that my chances of getting a diesel engine by them was second to nun so I guess that person was lucky..so I'm still open to any help..thanks ...johnny
451johnny
61
Stroudsburg
me again.. I looked more into that ( buy sell trade ) and I realize it is a very good place to search just have to post things to sell which I have allot lol..and put down what I'd like to get for it..any thanks again for this information I had no idea that an organization like this existed ...johnny
5,271
You have had several posts on the same subject all over the forum, no need, I've combined them all on this thread, please go back to the beginning of the thread and re read all of it for all the answers.
You asked the same questions back in 6-19 and the answer has not changed, neither a D600 or a D722, or many many other models will fit that tractor.
Like I said before only a D650, D750, D850, Or a D950 will be a direct replacement.
You also should not have D650 in you B7001, you have a D750, unless someone has replaced the D750, with a D650.
And FYI: There are 2 versions of the D850, and D950, and only one version will be a direct replacement for your D750.
451johnny
61
Stroudsburg
What does "damaged " mead and why wouldn't just repair what you have?
my B7001 Kubota 3 cylinder diesel engine blows white smoke I spent almost $700 in a Kubota dealer ship to have them tell me that the entire engine needed to be completely rebuilt and boy was I pissed.. they were saying between $3500-$4000 to rebuilt it ..the engine had to much wear and tear
451johnny
61
Stroudsburg
I had the tractor dropped off in a Kubota dealership for repair because it was blowing allot of white smoke only to be told that it would cost me close to $4000 for repair ..so I decided to search for a used motor ..I searched all over that freaken engine trying to some information I used a power washer in search for a model number in that engine and couldn't find any ..so I called the dealership and they said it was a D650 and to me it sounded like they were saying ( probably a D650 ) so I have a feeling you're right .QUESTION WOULD YOU KNOW WHERE that engine model number might be located on the engine??? thanks you so much for that important information...johnny
5,271
2 ways to find out size.
The size and serial number will be stamped on the block right next to the injection pump.
The CC of the engine will be cast into the block behind where the hydraulic pump bolts on.
5,271
what can you tell me about it and how much are you asking ??
The 22HP D850 I have is a completely all OEM parts rebuild engine, all new internal parts, it's essentially a brand new motor.
I'm asking $3500 just for the motor, or $5000 for the whole HST tractor.
Yea it's high, but it was a very expensive parts cost rebuild.
If you wanted a D750 rebuilt you can do it with aftermarket parts for cheaper, and if it doesn't need re-sleeved it could be done for about $1200 in parts and about $800 in labor.
If it needs re-sleeved that runs the cost up another $900.
So yes rebuilding these little engines are not cheap, and finding good used running engines is hard.
Send this Guy a message, he has been know to get a few good used engines that might work for you.
https://www.orangetractortalks.com/forums/member.php?u=27855
