My Big Lawn Mower!
Shawn T. W
Dec 9, 2024
809
1,468
SW Missouri Ozarks
Such a nice property to mow. 130 lb in a rear tire doesn't sound like much at all. My MX rear tires are 17.5-24 and hold 600 lb of Rim Guard each. Even with water they'd hold around 475 lb.
I only filled them 1/4 full, to keep it as light as possible, but a test to see if it was enough ... Its just a rough guesstimate ... I just filled it at about 7:30 position, and let any excess out ... These are 14.9-26's.
I'll probably try the 9 O'clock position next . . .
The problem I'm trying to avoid is too heavy, and rutting up soft ground, which I have "spots" ... My neighbor kindly reminded me after I buried my semi-truck in her barn yard before I got my driveway in ... That the town we live in is called MARSHfield for a reason ...
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,977
Near Lancaster, PA, USA
The R4's on my L4240 are loaded and grooved. I have mowed in the rain and they worked fine. It pushes an 8' Fisher plow - usually without additional ballast. I have nothing that requires me to operate in mud. It can get a little snotty when the creek floods.
I have been tempted to try some turfs a few times in the past, but the R4's have worked too well to bother.
Shawn T. W
Dec 9, 2024
809
1,468
SW Missouri Ozarks
I skipped around this area today!
Got stuck going forward, tried to pull myself out with the BH, as far as I could get, had forks on the front, no help! šŸ˜•
Shawn T. W
Dec 9, 2024
809
1,468
SW Missouri Ozarks
The grass in the front was getting tall, over 2' in less than 3 weeks, glad I buzzed it down to 3.5" then ...
I was a bit concerned that the finish mower would choke on this tall of grass, but going 3.7-4.0 mph seemed to do a pretty good job!
I got the idea from someone on a forum about cutting in a circular pattern ... Keeps the neighbors guessing if I lost my mind ... !
I did that today!
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,735
4,564
PEI Canada
Looks like it did a good job at that speed.
Shawn T. W
Dec 9, 2024
809
1,468
SW Missouri Ozarks
Yup! šŸ‘
I got the side/back done today, bumped it up to about 5 mph, as it had a bit less time since I mowed it last, so it wasn't as tall ...
Shawn T. W
Dec 9, 2024
809
1,468
SW Missouri Ozarks
Went to hook the mower back on, and found out what the large washer I found out laying in the field while watering went too ...
I scrounged around and found a new bolt, not sure why they painted over the orange, but I got the mower from a JD dealer that said the previous owner had a JD ... But ... The whole rest of the mower is orange, so why paint only this part???
Last time mowing I also lost a linch pin on the rear gauge wheel backing too far into the pucker brush, and when I went over a bump, I lost the top two spacers and a bushing from inside . . .
The other side survived!
I actually only noticed it when I went over a huge bump, and the rear of the mower lifted enough for the whole wheel to fall out, and I only had three wheels back there!
New parts ordered!
S-G-R
Jun 17, 2020
1,735
4,564
PEI Canada
I mowed 4 acres and then drove a half mile and realized I only had three wheels on the FDR2584. I did find everything walking back and now I make sure everything is in place before I leave a field.
Leave the green. It gives the mower characteršŸ˜†
Shawn T. W
Dec 9, 2024
809
1,468
SW Missouri Ozarks
What's crazy is the price for the official linch pin!
It wasn't in stock, so I asked them if they had a generic one? Yup less than a quarter the price, got a spare too!
Also crazy price on the spacers ... The 1/4" is more than the 1"? !!!
I'm gonna hook a wire somehow to those rear ones so they can't come out ... I will probably leave it at the 5" level anyways ...
chim
Jan 19, 2013
3,278
2,977
On those wheel assemblies I drilled the pin hole and used either the HD lynch pins (the ones with springs so strong they hurt you when they snap shut) or bolts with Nylok nuts.
AgriSupply has been a source of blades, spacers and some parts. Here's a place I bought replacement assemblies from for some refurb projects:
Sawdust&Shavings
BX1870,LA203A,BX6315,BX2767,RCK48-18BX,GCK60-23BX
Apr 25, 2023
221
263
Stafford, VA
New parts ordered!
Lynch pins can be purchased with different strengths, their strength is measured when it smacks your finger when closing; from:
1. What was that
2. That didn’t feel good
3. WTF was that
4. OMG where’s the Corpsman
Reactions: 6 users
Shawn T. W
Dec 9, 2024
809
1,468
SW Missouri Ozarks
Lost another linch pin today, this time on the front gauge wheel ... Not sure how that happened, but I caught it before I lost any spacers!
Also lost one of the pins for the QH top hook! Also no idea how that happened!
I mowed the front field at 4" as I already had the mower set up for that, I mowed around the barn first though, I usually use the Z-turn, but it's out of commission at the moment, had to be careful of the trees ...
And the fence! Luckily it was just leaning up against the cattle panels ...
Two weeks of growth ...
The ceramic tint I put on the right side door makes an AMAZING difference!
Then readjusted the mower to 5" and went out back, still hitting the occasional rock out there, I do like how 4" looks, but the back isn't ready for that yet!
Reactions: 6 users
Shawn T. W
Dec 9, 2024
809
1,468
SW Missouri Ozarks
Mowed the lawn again, even though I got the Z-turn fixed, grass was over 18" tall, took it down to 5" them buzzed it three days later with the Z-Turn at 3.25" ...
Mowed the front and sides and part of the back yesterday ... And went back out back this afternoon.
I was finishing up the back across the creek, and I heard a strange noise and felt "something not right" ... The left side gauge wheels had fallen off!
The back two grade 8 1/2" bolts had broken, front two nowhere to be seen!
I noticed on the right side that it had two new looking bolts, and two old rusty ones ... I'm not sure what I'm seeing looking back at the first picture in this post, wether it's two rusty bolts, or they are missing (I mowed about 3.5 acres since that picture was taken!)
I set it aside and drove up to the barn, got the Massey Ferguson and went and fetched as it was starting to sprinkle.
I went to town and got new bolts, grabbed some tools and red loctite, and put it back together, since nothing was even bent!
I then checked the bolts on the other side, the new looking ones took about a quarter of a turn, the rusty ones almost half a turn ... I'll have to keep an eye on them.
Shawn T. W
Dec 9, 2024
809
1,468
SW Missouri Ozarks
I also just remembered that I "topped" some of the weeds along the creek . . . Just lifted the 3pt a tad.
Shawn T. W
Dec 9, 2024
809
1,468
SW Missouri Ozarks
I raised the mower to 5.25" and cut the front field today ...
Alot of red clover is spreading out there ... I also saw over two dozen of these deer beds, but no fawns ...
It started to rain and thunder just after I started on the side field, so I came in ... Sat down in my chair in the living room and saw this out my bay window, guess she was looking for her bed!
Shawn T. W
Dec 9, 2024
809
1,468
SW Missouri Ozarks
I hadn't mowed this side field for a day less than 5 weeks, it was tall and very thick, the finish mower did a good job, but I had to slow down to 2-2.5 MPH
Cut at 5.25" high.
Shawn T. W
Dec 9, 2024
809
1,468
SW Missouri Ozarks
I went out this afternoon after all my hot "outside work" was done, to mow the back field, first pass around I heard a HORRIBLE racket that just wouldn't stop, I ended up turning off the PTO, lifted the 3pt, sucked in the top link and got out to look, sounded like I bent a blade! But all was well, no damage other than a beat up blade!
I've mowed this field quite a few times with this finish mower at 5", today was at 5.25", but I've mowed it as low as 4" with my little 4' brush hog ...
I picked up some of the bigger chunks of rock and tossed them in the nearby woods, then took a few of the small shards and dropped them in the hole that I dragged the rock out of, but ... Something MOVED in there!
I looked closer, and it looks like junior snake wasn't happy that I had violently removed his roof!
I scared up a few little 6" rabbits that ran off ...
That white flowered stuff that looks like, and may be Queen Anne's Lace, and the one with the little blue flowers behind it, have very tough and stiff stalks, and tend to pop back up only partially cut ... But at least I got the ragweed cut before it blooms!
Overall a good afternoon!
Shawn T. W
Dec 9, 2024
809
1,468
SW Missouri Ozarks
Got the other door tinted, plus the right rear quarter window too, that was a pain in many ways to do ... !
I mowed in a big circle today for a change of pace, made a silly video ...
Pinwheel mowing pattern!
84° outside, 70° inside, very comfortable, and a nice day to mow my front field ...
