My B2620 Pics
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,328
335
Had a thread on another forum I was a member of before I found this one. So I was thinking I should post some of the pics on this one, since it is a Kubota dedicated forum. Hopefully this will help show prospective buyers what a small tractor can accomplish.
I'll start with this......some of the one kilometre of bush road I made on my property for harvesting my firewood from up in the back yard.
I've moved just over 330 metric tonnes of pit-run B-gravel with the little B2620. (I know because i hauled it all home with the dump truck and every load was scaled.)
The hill is steeper than it looks in the pics, but I pulled that loaded 60 inch box blade up it no problem (tires not loaded either)
I bladed on that hill one day for 6.5 hours and only used 3 gallons of fuel!
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,328
335
This set shows some of the pit-run gravel I hauled up the hills one bucket at a time to build the roads with.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,328
335
The 04.5 Sportsman 500 H.O. helping out. This atv has been bulletproof. I plowed with it for 8 years before I bought the Kubota, skid and hauled firewood. Never changed a single belt or anything. Just tires and battery.
My new Polaris's.....not so much. Like many things today build quality has sure gone downhill on those.
I'll keep working this old one.
TRA
B2601, LA434, BH70, LP BB1260
Dec 17, 2017
88
Rock Hill
THANK YOU for posting these. Im going to be doing the exact same thing soon, with similar equipment.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,328
335
The beginning. In with the new and out with one of the old lawn tractors.
Between the mowing of 2 acres of finished lawn and the snow removal......what a huge savings in fuel with the Kubota versus gas powered lawn and garden tractors.
I can mow the lawn 12 to 13 times now with the same gallons I put in the 3 lawn tractors I've had.
And pics of my work fleet. The B2620, the Sportsman 500 and the self propelled John Deere JS push mower.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,328
335
While I don't mind the minus 40 degree winters on an open station (I have plow trucks from the business that sit parked while I play on the Kubota and Polaris) it does suck when you add in wind.
So I added a 12V power port to the B that is for the newer B2601 series and bought a G-Max Trekka GM11 helmet with heated shield. It works awesome!
Even when the snow dust if covering you the shield stays clear and dry and you are nice and warm.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,328
335
Some of the work tools. I bought a Braber Equipment quick hitch. It looks identical to the Land Pride but was a third the price. No issues so far other than it rattles lots.
Agri-Ease 1000 pound clamp on forks.
Land Pride BB1260 box blade and LP RB1660 rear blade with hydraulic angle.
I thought I needed the angle blade with all the road work I wanted to do, but for anyone on a budget.....there is nothing you can't do with a box blade and loader. I rarely put the angle blade on.
I find the box blade to be way more useful.
Also note the dealer installed rear remote joystick. It works for me, but would need to be re-engineered if you were to add a cab.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,328
335
My good friend and neighbour down the road bought this Wallenstein BXM32 chipper/shredder for us to both use. It works very good. I have put stuff bigger than 3 inch through the chipper no problem and the shredder literally turns leaves to dust I blow back onto the lawn.
As you can see I added some 4x4 wooden feet to the bottom of it. His new BX would not lower it down far enough for it to sit on the ground with his quick hitch on, so he would have had to fight to put it on and off. That was the only problem we found with it.
Love the forks for doing firewood and storm cleanups too. No more bending over to cut the logs.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,328
335
Doing firewood. My big splitter is home made by my father when he had the welding and fab shop. It was made in the late 70's early 80's? It was originally a Lincoln welding machine trailer. it's been through a few engines as he always lent it to all his friends who did their best to kill it.
It currently has a 1982 Toyota Tercel 4 cylinder engine on it.
But it's getting tired and hard to get parts for, so I recently bought a new Forest King 25 ton splitter.
It was 534 pounds in the crate and my B with the clamp on bucket forks lifted it off my trailer and carried it across the yard with no issue at all. I was pleasantly surprised. I didn't think it would since those clamp on forks add so much leverage further out past the bucket.
4,054
They are great pictures!
I've posted many pictures here, and the slope doesn't show well.
Some of yours look steep, so betting those spots are quite a climb!
Thanks!
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,328
335
Thanks for the complements. I like to show what these tractors can do. I always read the comments of "go big or go home", but many people don't have the budget, or just want the simpler cheaper maintenance. So as long as you don't mind the extra seat time, these little B's and BX's can do anything you need to do.
4,054
Hindsight - I should have looked at a B closer when I bought my BX. Your pictures bring that home. I think your model was on the short list.
Sometimes my BX isn't enough, but the front-mount blower was important and a big ticket. While I had 0%/60 months, I paid it off in 25 months. Not smart, but not a fan of debt.
I did look at a B last year, but the trade thing didn't work for me. I love my BX, but should have been more open to the B in 2013.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,328
335
RCW.....when I went to buy my tractor he gave me a B2920 to try out. Looking back now it would have been nice to have bought it because you can't get that h.p. now without a DPF muffler.
But I have zero regrets because I also don't like financing debt and what I saved on the B2620 paid for my box and angle blades. I had the cash for those, but wouldn't have had if I went 2920.
So far the snow blower or chipper have not taxed the 26 h.p. motor.
WillB
MF 1635, lots of implements.
Jan 26, 2014
25
Innisfil, Ontario
When I saw the footprint that the pit run left and then seeing the new road, I was beyond impressed.
These B’s are work horses.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,328
335
Couple pics of the LED lights I replaced my dealer installed halogen work lights with.
I think the forward light bar is 22 or 24 inch, 120W combination spot and flood.
Rear I put an 80W flood. Rear facing pics comparing halogen and LED.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,328
335
More of the LED lights at work. No issue with glare while in blowing snow.
They are great mowing too because they light up 360* around the tractor, so I can see the edge of the deck on both sides.
